My desktop cannot power on
shadow84
Guys, its really my psu issue. I have bought a spare psu and test. it work. seems that it's my psu causing the problem and long term issue. one side question.. during a year using my desktop.. i have encounter power trips due to lightning of bad weather. can it cause damage to my pc?
Then each time i call it a day, i need to off my plug to prevent wastage of electricity. Then how do i safety off my power supply each time i call it a day?
If ur psu is good, it will prevent dmg to other components.
wwenze
Do people buy $150 PSU that can't handle daily on-off which cheap commercial PSU can?
jtjt00
......... Then each time i call it a day, i need to off my plug to prevent wastage of electricity. Then how do i safety off my power supply each time i call it a day?
No need to off the switch on the PSU, just off the wall socket mains will do. This is my practice with both my desktops on the right -->
lalalalalala
psu itself got a switch, most likely beside the power cable. and don't need to off everyday la. the standby power consumption is really really low, spend less than a dollar a year better than buying new psu right
