My keyboard's letter u not working. How to cre it?
Reborn
not joking. Jst in case yo wondering how I managed to key in for the title. I copy and paste from other words.
Anyway to solve the prob other than getting a new keyboard?
stupidog
set up shortcut on your mouse ?
HelloEllo
There's a windows tool to switch a key. It's called Microsoft powertoys.
You swap the key lor. Change U to say another key. Can use windows or alt since got both.
Downside u is quite frequently type need to get used to the change.
stupidog
got sch thing? can ah? how? sond slike good idea
if u are using logitech mouse, go to logi options to do it
uuuuuuuuu
fade_white
Looks like u solved the problem fine there
articland05
probably too much junk inside the keyboard.
time to open it up and give it a good wash...
make sure fully dry before reassemble back
