My own simple guide to better casing ventilation and cable management.
Gregko
nice server configuration.
RAMS galore,
Hard Disk galore.
btw what RAID card is that? highpoint?
Kiwi8
Deluxe Member
ragnarok95 said:
Just change to a new casing...haven touch up on the cable management yet...haha
Nice. I like the way the harddisks are placed parallel to the sides for easier access.
ragnarok95
Senior Moderator
Senior Moderator
Where got easier access?? :s13:
Also need to remove the whole cage to add or remove hd. Cos my hds are screw on, not inserted type :)
tecnica
my CM534 also liddat.. very easy to remove the hdd :o
elpibe10
Soldam's design lousy IMO. Still prefer Lian Li. Easy to install & remove PLUS reduce HDD vibration and noise.
ragnarok95
Senior Moderator
Senior Moderator
Then you still buy so many?
elpibe10
HDD cage is only a small factor in the overall casing design. Furthermore, I only have 1 HDD per system so can live with this shortcoming. Basically, more Pros than Cons. :s13:
Maybe I'll have to improvise something to reduce the noise and vibration. :D
ragnarok95
Senior Moderator
Senior Moderator
I dun know....i like my FC500....this casing will be with me for a veri veri veri long time....
Who want my soldam super X super hybrid??? Selling price is only S$270 :D
I got the super X for S$350 le :( :(
elpibe10
Same for my XR-2JV B.K. and Antec P182. Finally using something I really like.
Previously made some stupid choices esp. with the CM Mystique 631.
elpibe10
2nd hand lose only $80 very good liao. Percentage wise, I lose more than you when I sold my PC-A07.
elpibe10
ragnarok95 said:
The current ZR2000, i feel not as good as the XR2.
What's the diff.? Looks similar except for the side ventilation hole design.
Hmmm ... let me go take a close look.
ragnarok95
Senior Moderator
Senior Moderator
Yes, the side ventilation holes that your XR2 dun have. IF you open up all of them, chances are, the front wont be taking in enough cool air...kns...
elpibe10
Mine have. Just different design.
I didn't open up to check but the readings from the mobo and Kama-Meter show very acceptable temps leh ... CPU and NB about 4 deg and 8 deg above ambient at idle.
Full load CPU never exceed 40 deg C before.
ragnarok95
Senior Moderator
Senior Moderator
Your front fan aucking in air? Last time u were complaining it didnt right?
elpibe10
Last time got 1 fan in front, now got 2. 1 x 120mm & 1 x 92mm ... both Scythe Minebea Low @ stock speed.
Refer to photo in my earlier post. :D
Lss
how can i make this mess neater? i will be getting L connector sata cables so i would most likely be adding a fan. especially the mess at the bottom usually how do you hide those.
actually i have a 2nd hdd which i cant find a place to mount. i will also be swapping to a sata optical drive once comex starts.
jtchoy
The mess at the bottom - cable tie the casing cables and straighten them and hide the excess at the front panel. Refer to my post earlier.
http://forums.hardwarezone.com/showpost.php?p=24638872&postcount=59
