MyRepublic fibre - Part 4
romanohairi
Going to go with MR after all the bullshiat from singlet, stuckhub, Mnotnumber1.
Will I still require to have technician to come and set up something even when I already have existing connection? It's not too difficult to connect the devices right? Problem is I'm not at home quite often..
Yes bro. The engineer still need to come down n install the ONT.
romanohairi
Hi MR 15 Jan 2014, i went down to the shop in AMK hub to sign up for the ultra plan. but the sale person told me as the plan only can start register on this coming saturday. he will help us fill up the form and sign but only submit the application on this saturday as he wasn't sure what to write on the remark session.
may i check with you does my application still count a not? as i didn't do it thr online but going to the store instead. =) thanks in advance.
It's best u contact the shop on the status. Coz those who sign up with me or other authorized partners, we will update our customers personally.
noobiee
if i sign up for 1Gbps plan, what is the earliest time i will get it running?
new customer, no other fibre contracts, opennet box is ready
romanohairi
My Fibre cables all laid already, still need someone to come ah. Wah Sian...Later queue so long I not able to make it is really Sian...
Yeah, bro... they still need to verify u get the speed that you subscribe for. It's the business process.
summersky1986
MR personnel just installed MR for me.
On full reception wireless.. I'm getting this... wah lau 100mbos only get this.. not acceptable man.. can someone help me out please?
suzuka88
Where did u see that? Probably 100mbps plan.
i sub during amk branch open . i call and email after 12 mth contract over it will be 59.90 ...i was laughing behind my phone .
100mbps plan is 59.90. i guess MR need to brush up the sales rep:s13:
Mach3.2
Run on wire la...
No provider can guarantee your subscription speed on wireless...
To much variable in play...
romanohairi
Yeah bro... If no contract, 100mbps is $59/mth. Unless you re contract, then u get the promo price. .
Mach3.2
OTP in living, I bo bian leh :vijayadmin:
channel surfing now to find the optimal......
Then suck thumb liao lor..
The wireless speed seems reasonable if you're using 2.4GHz..
5GHz can give you better speeds, but if got many many wall the signal ish rike shiet..
2.4GHz propagate better than 5GHz.
Phen8210
actually more or less will be the same one.. cos most ppl set their router to auto it will also squeeze wif ur channel if urs is quite empty.
