Does that mean that when I call in, your line won't disconnect me after x minutes on hold? Does that mean when your CS staff say give me a call back, you will call me back automatically?
Youku not working on ipad tho,
Geoloc deny..
this is just a interim solution. soon, the slowness would come back again. they need to peer with reliable china counterparts.![]()
We will further increase our CS strength over the next few days to ensure calls are picked up within a certain period of wait time. If customer waited on the line for too long, we will monitor and do some check and call them back in the evening or the next day.
This is to ensure every single customer that called in will get answer.
as expected, MR has to troubleshoot subscribers problems as such laptop/os/software/wire/router..
good luck getting traffic lights to do that.
1gbps simply doesn't work out of the box for everyone.
even some of the latest consumer routers are only capable of approx 800mbps WAN to LAN
some of the usual jokes will still be seen, e.g.expecting super speeds over wifi
Hi,
If you look at below pic, The speed is somehow in line with my Ethernet speed of 1Gbps (730Mbps vs 1Gbps). Yes it is a big improvement since last complain. Is it acceptable??
If you look at below second pic, The speed comparing Wifi internet connection is horrible (82Mbps vs 150Mbps).
But wait!! How can I be getting 150Mbps on my Wifi internet connection property where it should be 1Gbps?? I am sure Lenovo Yoga 13 is capable of more than 150Mbp limit. Have I miss out anything on the AC68 router ??? What is it??? How to know if Lenovo Yoga 13 can reach more than that?? My network adapter is Realtek RTL8723AU Wireless LAN 802.11n USB 2.0
If you look at the 3rd pic, The speed comparing Wifi internet coonection is also horrible. (120Mbps vs 300Mbps). I can answer why its limit is 300Mbps because I am using Asus USB N53 Wifi adapter which the limit has capped at 300Mbps, but I am getting not even half of that on this 1Gbps plan. Again I am suspecting Router is the issue here. What did I miss out? Has anything been blocked??? Can the expert here advise??
The speed shown in your LAN or WIFI settings is not reflective of the actual speed you will get, because as long as the connection is gigabit/wifi speed it will just reflect it according. Example: u get a lousy router with gigabit, it will show 1Gbps but u sure as hell won't get 1Gbps because its a chui router. This applies to your LAN or wifi card as well. If you computer has gigabit LAN but very old there is a higher chance that it will not support the actual 1Gbps speed. Basically its as useful as only telling you if your stuffs are connected correctly
Since your Realtek RTL8723AU is a wireless N and using 2.4Ghz band, and u are connected at 150Mbps I am sure your windows wifi card settings is connected at 20Mhz (which u should set to 40Mhz or auto) OR that your Asus router 2.4Ghz band is defaulted to 20Mhz only (again set it to 40Mhz). After doing that you will see it jump up to 300Mbps (I assume your wifi card is a normal wireless N card) but that doesn't mean that your actual speed will increase. Basically its the same idea as the LAN speed I've explained earlier on.
What you should do is to connect at the 5Ghz spectrum to hope for any improvements, however u will not see 1Gbps speeds because AC68 max you will get around 200-300Mbps and thats with an wireless AC adaptor. This applies to your USB-N53 as well.
if i'm not wrong, the realtek should be 1t1r card
No idea I can't find any specs while googling so I assume its 2T2R. Plus there is a chance that Windows defaults it to 20Mhz. if its 1T1R then 150Mbps is the max liao too bad for him![]()
nowadays laptops come with crappier wifi cards than my 6 yrs old centrino laptop
5ghz looks wierd though, upstream higher than downstream.
oh well, so many possible reasons for that
Guess its because last time laptops only comes in 4 digits price. Now its 3 digits price so they have to cut corners![]()
you'll be surprised, stupid asus gaming laptop come with a 1t1r 2.4ghz wifi card.
which is why i went aftershockpc.
After all, Singapore's fibre-broadband rates aren't quite as attractive as Hong Kong's.
Ms Serene Chan, research director at Frost and Sullivan, told me that a 300Mbps fibre plan in Hong Kong can go for $48 a month, compared to $86 monthly for a 150Mbps plan here.
huh serious? lol wtf asus. they expect u to game using wired perhaps.
And if we go below 1Gbps, we can certainly do over provision to over come the speed lost from our network to the end device. But at 1Gbps, there's no way we can do over provisioning despite the fact we would love to do so.
