For those thinking of getting Fire TV, you may want to note of some content limiting algorithm possibly set by Amazon to give you the full media experience. Read more here
Why Roku Matters More Than Ever
Our installer are working extremely hard, rushing from places to places to get everyone's connection up.
Even machine cannot tahan (Car broken down) =(. So please bare with them if they are late by a little or so.
Try manually inputting the DNS into the iPad.
one thing I don't quite understand is why Teleport can only work with select streaming settop boxes as well as severely limited contents while using them.
correct me if i'm wrong, but aren't all settop boxes connected to the same router in your home which supplies the same DNS to all devices in your home? And that DNS is dictated by MR so why are you able to watch so many streaming services on PC but not as much on phones/tablets/boxes?
whats the crippling factor here?
Hi Representative of MR,
How can i reached anyone of you?
1) I've called hotline for days without anyone picking up.
2) I've sent email to customer service & Solomon Teo without any response.
3) The live chat function seems permanently offline.
Regards,
Customer ID: C1005736
Regards,
The speed shown in your LAN or WIFI settings is not reflective of the actual speed you will get, because as long as the connection is gigabit/wifi speed it will just reflect it according. Example: u get a lousy router with gigabit, it will show 1Gbps but u sure as hell won't get 1Gbps because its a chui router. This applies to your LAN or wifi card as well. If you computer has gigabit LAN but very old there is a higher chance that it will not support the actual 1Gbps speed. Basically its as useful as only telling you if your stuffs are connected correctly
Since your Realtek RTL8723AU is a wireless N and using 2.4Ghz band, and u are connected at 150Mbps I am sure your windows wifi card settings is connected at 20Mhz (which u should set to 40Mhz or auto) OR that your Asus router 2.4Ghz band is defaulted to 20Mhz only (again set it to 40Mhz). After doing that you will see it jump up to 300Mbps (I assume your wifi card is a normal wireless N card) but that doesn't mean that your actual speed will increase. Basically its the same idea as the LAN speed I've explained earlier on.
What you should do is to connect at the 5Ghz spectrum to hope for any improvements, however u will not see 1Gbps speeds because AC68 max you will get around 200-300Mbps and thats with an wireless AC adaptor. This applies to your USB-N53 as well.
Delays in 1Gbps broadband delivery on The Straits Times April 5, 2014
MR came down to install my fiber yesterday. End up, OpenNet TP has no signal, so it's OpenNet's fault now. Why is the TP off in the first place? Why MR cannot liase with OpenNet to check the infrastructure first before making a wasted trip?
Will I be bumped to the back of the queue (i.e. be one of the last ones to get wired up)? Any priority? I don't have internet connection in my house now and I am wasting my data plan to surf on my laptop. Oh yeah, waste of leave
Youku not working on ipad tho,
Geoloc deny..
I am starting to get this ridiculous speed this morning after all these bad / negative news today:
2nd day come back from work, 1st thing test the MR connection... guess nothing is change, there goes the 1Gbps connection. It really make you happy for just for 1 week and now the bandwidth is been control now.
OK this morning do some experiment to test connect directly to ONT and got this result
So the problem is from the router I guess. So now to get back the connection I have the first week? Here is what I did.
1) Download the latest FW from ASUS RT-AC68U Firmware version 3.0.0.4.374.5047
Test the connection still same very low ~ 350+ Mbps down and 450+ Mbps Up
2) Reset the router to default factory and start from beginning. Setup all the wireless blah blah...
Test the connection and this is what I get![]()
I hope this is permanent, cause is annoying if we have to do this every time if we detected our connection did not hit the mark. Indeed 300Mbps for me is already good enough just that we consumers would like to have what we subscribe for right?
Will keep monitor till next week and see how it goes.
Hi nivleK1985, thank for the pointer, I keep you inform if I find any abnormal connection.
Cheer guys
Cheer guys
We need to find out what is the root cause on our router (mostly asus class router) that is somehow restricting the bandwidth, only to reach full capacity upon hard reset.
Cannot be always resetting when bandwidth reach below optimum level right? Like that we very busy.
