MyRepublic fibre - Part 4
Lehnsherr
plp is premierleaguepass
mine is as smooth as butter
How's your hola performance on china streaming sites other than youku or tudou? Mine always slow or resets itself on places like iQiYi, huashu TV, if yours its fine then I guess must be MR.
wyfitms
dont depend on an isp to help u stream videos,
since their support here is almost zero, guess they have all bailed out,
can just use hola unblocker.
once log into plp, switch off hola to stream smooth.
bro how did u do it...
once i switch off hola, the page auto redirect to blocked error
if i leave hola on, and launch the game, the new window which opens just loads forever,...
kira86
i have no problems streaming any videos from the first day . no problems on youku, or twitch :)
oh yes, forget to add, i'm not on MR, decided to pay more for better internet experience .
Lehnsherr
lol I know exactly what you are on.
heng twitch I don't watch, so no issue for me. Youku only got well after I got on the 1Gbps. Can last or not I not sure.
So you mean that hola works on all those other china streaming websites (other than youku and tudou which its ok on mine) flawlessly? Thanks.
kira86
i dont use hola for china, only using it to get into plp.
better take my leave here before the MR fan boys comes in.
Lehnsherr
Well my usage is opposite of yours. but nevermind thanks man. :D
no worries there are no more fanboys in this thread for a long long time. :s13:
xRenol
Video streaming on Youku is okay for me but I don't watch Youku everyday.
MRUSER
This MR fibre is really crap! Damn slow and not stable network! Worse than my mobile and Singtel 6mbps! Hope you guy really check before sign up this crap!
IndigoEyes
I need help...
I've the same problem for nearly a month and still not solved.
Symptoms
- Every several minutes or couple hours, anything on the internet became very slow and some pages not found.
- I have to reboot the router every time from that IP address page to make the internet usable again.
The technicians came twice, did different solutions but problem still there.
First visit:
A technician replaced the n56 router and optic fibre cable. Did a power cycle. Problem still there.
Second visit:
Another technician told me that he cleared some downloads that were stuck in the router. (I've no idea what it is since I've no IT knowledge.) He also told me to get an extender. (I didn't get it since I've no idea what is that too.) He said that alot of people who called up the tech had the same problem and it's due to the large file downloads during the previous years.
The problem is still there.
But.. I had to download something on that day.. I did it without an extender which the 2nd technician advised me to get. I'm not sure whether it was due to that? If it is, how do I clear the "downloads" stuck inside that router?
I tried to put back the old ESR9850 back.
With or without the network turbine, the internet still have the same problem. So it's not the router's problem.
However, right before they come and installed the 1Gbps, my 100mbps plan had no problems at all. So it's not my computer's problem too.
How do I go about solving this? Call the MR tech again? ><
It's like so hard to call the MR tech.
xRenol
I need help...
Symptoms
First visit:
Second visit:
Have you try direct connection from ONT?
Lehnsherr
I don't understand. Is ONT the box on the wall? You mean attach the wire from that box (wall) to the desktop?
TP---->ONT------>Router
Its the one that you connected to your router. So if you connect direct to it instead of router it becomes like this:
TP---->ONT------->PC/Laptop
However the connection from ONT to PC/laptop must be using the LAN cable. So if you dont have a long enough one u wont be able to test. Unless u have a laptop to test
imacbie
Seriously ??!! Downloads stacked over the years??
What weeds the tech been smoking??!
