MyRepublic fibre - Part 4
misato
Sigh, even though my republic is fast, the organisation is just not structured to support business. 3 days lapse since the request to upgrade static IP from 1 to 8, and still getting no where... Its really up to you if you want to keep this customer who is growing, or lose this customer to another provider that can support an enterprise. You have 1 year 11 month to buck up!
When was the last time you send such a request to say Singtel or Starhub. Unless you are prepared to pay for express service, its a typical 2 weeks standard to provision such a commercial request. Thus 3 days and nothing happen is still well within the usual threshold.
azrin619
What eactly you need?
you need to go to the WAN page and set... similar to n56u
MyRepublic - I Need Help!
but yu need to give mr yr mac address first.... else don't work unless u set the cloned mac that you have provided them with.
still fails? call me lor...
Phen8210
hi should i update my firmware for rt-n15u router?
is it stable? anyone tested it yet? any problems encountered?
azrin619
if you use the ORIGINAL FIRMWARE provided by ASUS..then you are safe.. else.. anything wrong.. you are dead duck
azrin619
Wa don't wanna comment..later kena paste duct tape....
that said.. so far the current version 2013.08.07 update is official and inside the current routers... so no need to update lah.. unless you wanna tweak here, there.
Cryptrus
hi, i am setting up my NAS for remote access.... however my port forwarding all failed ad when i test the opening, i get connection time out. then i realise by WAN IP is 172.XXX while the test shows my external IP as 103.XXX... my guess is due to the private IP 172. assigned causing the issue.
Anybody doing NAS remote access can advise? running synology. the phone apps no issue to access. expect using another pc outside the network.
romanohairi
Hi Bro,
do you applied for the static IP? if you don't, then u need one if you want to access your NAS from external. I've PM you on the ports info for synology NAS... Hope it helps... :s22:
Cryptrus
Hi Bro,
thks. ya ...juz found out i need static ip
azrin619
If you hard code IPv6.. you might get that to work.. I'm trying on a solution bypass using natural NAT filters
Nights
I'm on MR Gamer. I try to watch video in tudou, super can not make it. Using starhub 25M cable streaming is very smooth. Is this normal for MR?
OMG, did a speed test to china server less than 1M.... Anyhow hum dum an US server in new york, less than 5M......
