MyRepublic fibre - Part 4
shadow84
My contract for 1st yr will be after 2 mar, and checking online, my installation date is Q3 2014 onwards. Can i say that if i sign up on IT show, in which i will enter my 2nd yr, my installation date will be Q2?
xRenol
According to this chart, the WAN to LAN throughput (which is a measure of router download speed, measured with a wired connection) for n56u/ac56u/ac68u are 802/778/754 Mbps respectively.
Thanks.
ASUS AC routers are lower in download speed?
skn_16
Norton Internet Security
For those that used the Norton Internet Security (NIS) that came bundled with the old Pure plans, moving over to the new Ultra plans looks like it is chargable...
runforyourlife
Moderator
Moderator
Upgrade now, you can arrange date of install with the order team when they call you closer to the date, you can ask for a later date worst case, or earlier date in Q3 if it works.
thanks. i hope the transition is seamless one :~
ngbc
Thanks.
That were the results of their benchmark test, I'm interested to see how accurate it is...
Will know when you guys on MR 1000Mbps post your speedtest result then!
Congrat to all MR existing users, can upgrade without penalty even when still in contract !
Lehnsherr
Not really for me. Mine is in Q2 and my contract also ends in Q2 with May and June free months.
If they install for me in April then I will lose the 2 free months. If they come install for me in June then I will see people use 1Gbps and I am 10x slower. I lose both ways :s13::s13:
Jin_GY
So as to say, existing customer with contracts (mine till early June) if choose to upgrade to 1 Gbps will have to pay 58 OTC?
CSO of MyRepublic, all these offers ($100 off router) and subscription at $59.99 will be staying for good? or only during this launching period?
PetPet
Moderator
Moderator
Hello!
I signed up last year am I eligble?
Also, I see Static IP ($50 setup fee) as an option.
Isn't it a one time setup fee?
Boltersdriveer
Hi Jin_GY,
Nope, if you look at the recontract page, OTC is waived off. Right now, the offer is that Ultra will be for $49 and $59 for ULTRA Gamer. U.P is $89 and 99 respectively.
Bolts
Boltersdriveer
Hello!
Hi PetPet,
Yep, eligible. No worries on the Static IP, just leave it there - it's supposed to be just a one-time charge.
Bolts
User123456
Norton Internet Security ($1.88/mth)
Norton Internet Security for 3 PCs, with 3 months free, on a yearly subscription.
My current bill = $ 59 for 24mths with free installation if i rem..
After less 5 free mths promo = [ $59 x (24-5) ] = $46.7
After less Norton = $46.7 - $1.88 = $44.82
My Pure 100Mbps vs New plan 1Gbps = $44.82 vs $49.99
:s39:
Jin_GY
Hi Jin_GY,
Nope, if you look at the recontract page, OTC is waived off. Right now, the offer is that Ultra will be for $59 and $69 for ULTRA Gamer. U.P is $89 and 99 respectively.
Bolts
Hi Bolts,
thanks for the prompt reply, I see the drop down list from the "choose promotion" includes a OTC-$58. Anyway, like one of the forumer said, If the last two months is a free month, how?
Lehnsherr
Hi Jin_GY,
Bolts
Actually the recontract page for me says OTC waived, but when I finished and get confimation email it says:
"You have ordered: Ultra 24 months - $49.99/mth - OTC $58 - 24 Months Contract."
So waived or not? I not sure. lol.
Jin_GY
Precisely! i'm confused with the description, even thou the recontract page said waived. If you read it again, it sounds like you have ordered a OTC which cost 58. hahah
khairulsal
Yes mw too..only a few days on pure hd plan. Isnt fair at all. They should hv inform us on this new plan as we can wait. Hope they do something bout it
I hope MR will do something about plan Pure HD plan which was only effected on Jan 10.
I m only a few days old and I hope to get upgraded to Ultra 1gbps with a waiver
skn_16
Hi Jin_GY,
Bolts
Bolts,
Lawzer's earlier post say that existing customers on contract the OTC not waived, got to charge.
Boltersdriveer
Hi,
Just to clear up on the OTC...
1) If you are still under contract and upgrade, there will be a $58 OTC.
2) If your contract has ended or is ending, you will not have to pay the OTC.
Bolts
Boltersdriveer
Bolts,
Yup, but it depend on when it is timed (e.g. Q2 2014 upgrade meaning that his contract would have ended/ending by then :)
Bolts
