MyRepublic fibre - Part 4
danxiaogui86
Done! :)
Your estimated installation date is Q2 2014 onwards.
Thank you for your application! Here are the next steps on your way to getting your upgrade!
danxiaogui86
Does MR cover the warranty for the ASUS routers (N56U, AC56U and AC68U) or ASUS distributor?
As long as the Asus Router is purchased from MR, MR will cover the replacement of the routers as long as you still under contract with them.
For example, router warranty 3 years, mr plan 2 years. Upon the 3rd year, you can go directly to the distro to replace if faulty.
Da Tou
Hi,
Just a quick question to find out my termination fee if I were to change to MR, see anyone can help anot.
My current contract with singtel ends at 11/6/2014,
Monthly is about $116, If I want to jump over to MyRepublic, when will my contract MR start? and when would I terminate my current plan? (since termination fee= Subscription x remaining mths in contract)
I think your MR contract will start upon installed and activated.
Hmm, anyone know whether is it possible to make arrangements such that the installation/activation occur on 11/4/2014 or later? So as to keep the termination charge to a minimal, Since 2 mths early cancellation for me is around $232.
shadow84
I believe you can request for a later date of installation, if you are within the Q2 2014 installation period. I requested for mine to be 6 mths later... Signed on sept 2012, activated on mar 2013.
xRenol
Thanks for the reply.
I have PMed you on a couple of questions.
shadow84
MR so fast kena SGAG-ed le...
omg_88
Hi I am at the order page to recontract. However, I can either use my existing router or choose from the 3 options.
But the questions is, which router will be able to support the 1Gbps download speed?
shadow84
If its wired, N56U or ur current will do, as long as it has gigabit lan ports.
If it is wireless, NONE in the market for now.
danxiaogui86
Thanks for the fast reply.
Is it possible to change to another ASUS router after I submitted my 1Gbps re-contract application?
when they call u to fix appointment, you can highlight your concern to the CSO that call you. :)
omg_88
First of all, thanks for your reply.
Does the below screenshot show that I have a gigabit lan ports?
omg_88
Ok thanks for the helpful replies.. Just to make sure my desktop can enjoy the highest possible speed as I am using wired even for now.
Guess I will stick with my RT-N15U.
Cannot wait for them to install!
xRenol
I am done too.
Your estimated installation date is 1st March 2014 onwards.
shadow84
The N56U is at quite a good price though. Can use for other wireless devices as well.
I am done too.
You 1st timer or recontract?
