Need a pc for dota 2.
littleprayer7
The price difference quite small, better still if can find 960 at good price..
But really, 750ti can play at high settings, just need off some of the options if not good luck during those huge aoe spell clashes.
you mean normal dota 2 or dota 2 custom games?
MoneyFace =p
Ts want play at highest settings.. And you tried which dota 2? Dota 2 reborn (source 2 engine) need better graphics.
Yup have seen latest reborn dropping to 30 fps on heavy scenes. So here's the amended build:
CPU+MB: Intel Core i3-4160 + ASRock H81M-HDS R2.0 @ $237
RAM: Kingston ValueRAM DDR3-1600 CL11 8GB @ $56* (Lazada Singapore)
GPU: Zotac GTX 950 2GB @ $232* (Lazada Singapore)
SSD: Sandisk Ultra II Plus 120GB @ $73^ (Lazada Singapore)
HDD: Western Digital Blue 1TB @ $77
CASE+PSU: Armaggeddon Nanotron T1X + FSP Hexa+ 550W [80 Plus] @ $85` (Lazada Singapore)
OS: Microsoft Windows 7 Professional SP1 64-bit Product Key [OEM] @ $30 (Reddit)
Upgrade for free to Windows 10.
Total: $790
Buy others from PC Themes, #04-15. Haggle for discounts!
Lazada prices after Shopback.sg 5% electronics rebate
*Price after Lazada App MasterCard Monday / DBS/POSB Appy Friday / CITIBank Wild Weekend 15% off max $25 discount
^Price after Lazada App LAZAPP $15 off minimum $75 discount coupon
`Price after Lazada App $20 off minimum $100 discount coupon [TBA later]
sacredrays
Normal lor.. But that was during the time reborn just released, maybe now got graphics improvement perphaps.. Later I go home try again then tell you.
As for 10 v 10, my current settings still suffer a bit though..
littleprayer7
I see.
10char
littleprayer7
Total: $790
Thanks man. I remember weeks ago there's a $209 or something palit gtx950 (minus off discounts and stuff). Will it be up for sale again?
MoneyFace =p
No idea too. Convergent already mentioned before Palit stocks will only be back in December, but that still doesn't mean there will be any flash sale for it.
littleprayer7
Oh... Then will need to get zotac one liao since it's the cheapest gtx950 right now.
CrowsZero
Yup.. 750ti 10v10 not able to run full setting recommend something better then 750ti
Hua_Hui
Palit 950 in stock liao but at 270 I'll go with zotac 950 or 960
sacredrays
ok i just go see see my dota 2 just now... if check all the graphic setting option, in normal matches, those huge clashes might cause your fps to drop to around 30-40+ fps, still playable but i rather pay a bit more get better gfx card.
littleprayer7
Cool. That means performance of gtx750ti in 10v10 dota imba will not be that good already.
Gribber
Agree,pay abit more for future proof
toRRez
sorry hijack this thread.
i'm running this setup now.
amd x4 640cpu
biostar a880g+
kingston ddr3 2gb x 2
powercolor 1gb 5770 ddr5
i manage to run dota2 on it before the reborn update.
but now in reborn, halfway during a game, my whole system will restart.
i tried doing a memtest but my com will restart during the memtest.
does this means my ram is spoiled? is the setup enough to run dota2 reborn?
if not, can i just change the graphic card or need change the cpu and motherboard also.
El Metronome
sorry i also hijack this, while we are on the topic of dota 2 pc specs.
sexperts here always said dota 2 is relatively less demanding of your GPU. but i dont seem to be able to run my dota 2 at max settings with 144fps (I'm using a 144Hz monitor), with my r9 290x.
i get that a single r9 290x is not exactly top of the line GPU power, and asking for absolute maximum dota 2 graphics settings on 1440p 144Hz is cranking the demands pretty high. was just wondering if its normal to be running at ~100fps normally, drops to ~60 during intense moments.
sacredrays
are you able to reach higher fps if you lower the graphics settings? if so, then yea, your gfx card performance not enough lor.
sacredrays
amd x4 640cpu
biostar a880g+
restart or bsod? did you monitor your temperature?
toRRez
Restart. I need to let the com 'rest a while' (abt 1min) before restarting. If not, the com will load till the windows screen and restart. I did not manage to monitor the temperature.
Goodshot
I thought most of the game now they auto adjust to 60 fps?
