Need advice choosing a pre-built pc
davidtanthree
Hi guys, im currently looking at dreamcore, invaderpc, define.pc and mansa. However the GPU that i want which is the 5070TI, invaderpc is the cheapest with very good cpu comparing to the rest.
INVADER PC:
AMD RYZEN 7 9700X 3.8GHz 8CORE/16THREAD
MSI B650M GAMING PLUS WIFI 6E MOTHERBOARD
THERMALRIGHT AQUA ELITE 240 BLACK V3 ARGB AIO
CRUCIAL PRO DDR5 BLACK 6000MT/s 32GB(16GBx2) CL36
MSI GeForce RTX™ 5070Ti 16GB VENTUS 3X OC
CRUCIAL E100 1TB 5000MB/s PCIe Gen4 SSD
SILVERSTONE TRITON TR750R GOLD PSU
DARKFLASH DS900 BLACK
3 X 120MM ARGB FANS
HIGH SPEED AX WIRELESS AND BT | WIFI 6e* + BT 5.3*
at $2.1k
as im not very well versed in the PC world, can i get some advise if the specs and components from invaderpc are low quality?
I have asked dynacore, bizgram and they charged higher after the quotes.
Thanks in advance!!
GotBetrayed
I used this decibel meter app in playstore
U want try use same app to compare?
Or what app did u use?
Decibel x app. My other setups is 30 ish db. So I know obviously my new 5070ti/9800X3D setups are louder than usual. May need to send back to aftershock for diagnosis
Vanyel
just ownself identify if its casing fan or gpu fan
i used to do that last time when i get irritating noises from my fans
proper way is probably to connect disconnect 1 by 1 but i did mine the lazy way
i just use my finger stop the fan 1 by 1 to find the culprit fan lol
GotBetrayed
I used fan control to test 1 by 1. Doesn’t appear to be casing fan. Need try again when I visit my dad’s house next time
