Need advice for building a computer
JRRRRR
Hey guys,
Thank you for reading, any help would be great.
I'm looking to build a gaming computer for the first time, but I don't have much knowledge and time to do the necessary research. Thinking to dump a shopping list at a sim lim shop (please recommend!) and get them to assemble one for me.
  • Budget ~$1500-2000, include monitor and mouse
  • Looking to play Dota 2 on full specs, would be good if I can play other high end games on decent settings
  • Playing Football Manager on full database loaded, full graphics settings
  • Will be situated in a non air-conditioned room, not sure if that requires a stronger cooling system
Any help would be lovely, will be very grateful :)
Thank you!
EienShouko
What other high end games do you want to play?
1.5k to 2k is too much budget if you just want to play Dota 2.
JRRRRR
Thanks for your response.
If that's the case just ignore the stipulated budget. lower the better :)
I only play Dota 2 now, but it would be good if the rig can handle other games like Titanfall, crysis, COD series at a decent setting if I ever wanna try them.
Jian19
i5-4440 + Asrock b85 killer ~ $345
Crucial 8gb ddr3 ~ $90
Plextor m6s 128gb ssd ~ $120
Wd blue 1tb ~ $74
Leadtek gtx760 OC ~ $340
Fsp aurum s 500w ~ $89
Samsung oem drive ~ $21
Sharkoon bd28 ~ $77
Win7 64 oem ~ $115
Dell s2340l ~ $220
$1491 buy and DIY @ tradepac ask for discount. If not sure how to DIY can bring to gs shop ask him help u assemble @ a fee. Mouse up to u see which type u like..
JRRRRR
Wd blue 1tb ~ $74
Sharkoon bd28 ~ $77
Win7 64 oem ~ $115
Dell s2340l ~ $220
Thanks for the help!
I don't mind paying 100-200 more for a better GPU, so I kinda came up with the following after scouring around the forum. I'm quite concerned about overheating issue, as mentioned the rig would be in a non-airconditioned room.
What do you guys think:
CPU + MB : i5-4570 + Asrock b85 killer $357
Ram : G.Skill RipJaws-X DDR3-1866 CL10 8GB Dual Channel Kit [Red] $115
SSD : Crucial M500 240GB $175
HDD : Western Digital Blue 1TB $72
GPU : PowerColor R9-280X 3GB PCS+ $438
PSU : FSP Aurum S 500W [80 Plus Gold] $89
ODD : Samsung oem drive $21
Case : Sharkoon bd28 $77
OS : Win7 64 oem $115
Monitor : Dell s2340l $220
MoneyFace =p
Max out Titanfall, Crysis 3...
Definitely fine in non air-con room.
CPU+MB: Intel Core i5-4440 + ASRock B85 Fatal1ty Killer @ $345
RAM: G.Skill RipJaws-X DDR3-1866 CL10 8GB Dual Channel Kit [Red] @ $115
GPU: PowerColor R9-280X 3GB TurboDuo @ $435
SSD: Crucial M500 240GB @ $175 (t258jgn)
HDD: Western Digital Blue 1TB @ $72
ODD: Samsung 24X CD/DVD Writer [OEM] @ $21
PSU: FSP Aurum S 500W [80 Plus Gold] @ $85
CASE: Sharkoon BD28 [Red] @ $77
DSP: Dell S2340L 23" LED [eIPS] @ $219
MS: SteelSeries Kana V2 @ $59
Total: $1603
Buy others from Tradepac, #05-18.
JRRRRR
Total: $1603
Thanks! plus OS so I guess $1.7k...
ykgoh
You can also dump the list to fortran and see if he can get the parts you want with the same price. If he can, he can assemble and deliver everything to your doorstep.
JRRRRR
trustworthy and reliable? sorry i'm a bit skeptical, just want to be cautious.
royfrosty
Slightly more premium parts.
MSI B85 G43 Gaming + i5-4570 ~ $384 (take advantage on Killer Ethernet Priority internet usage patterns)
Gskills Ripjaws 1600mhz 2x4gb kit ~ $113
WD Blue 1tb ~ $75
Samsung Evo 250gb ~ $180 (Amazon set) Performs faster than the crucial m500
MSI r9 290 4gb Twin Frozr ~ $667 (Good thru next gen worth of games, able to max out all settings including high end gaming till now, able to use in conjunction with MSI Gaming App together with the board, to save energy, to be silent, to game, to OC all with 1 small gaming apps, as and when you need it most)
Seasonic G650 650w 80+ Gold Semi Modular PSU ~ $135 (Go for modular PSU. Save up on wires that you do not need giving you more space and less wires dangling up)
Corsair Obsidian 450D ~ $170 (A good solid chassis goes a long way)
Samsung ODD ~ $21
Windows 7 Home Premium 64bit OEM ~ $110
Total ~ $1855. Buy at tradepac. DIY or alternative pm fortran
JRRRRR
I took a trip to SLS today with the following list:
OS: Win7 64 oem
Was advised by the nice gentlemen at gs shop (#02-32) to swap out the CPU and MB for 4590 + H97 Killer. I was also told that R9-280X seems to have a lot trouble with heat issues, and that GTX 770 would be a better alternative.
ASRock B85 killer and FSP Aurum S 500W are out of stock at tradepac and PCthemes as well.
Looking to find better alternatives CPU + MB, GPU and PSU. Buget $1500~1700. Any suggestions? Thanks for all the help so far.
JRRRRR
WD Blue 1tb ~ $75
Samsung ODD ~ $21
Hey thanks for your suggestion, appreciate it.
But it's a bit over my budget, still need a monitor, would be good if i keep to 1500-1700... not really a hardcore gamer, currently playing dota2 only but looking to try the latest games at decent settings.
ykgoh
If you can trust a SLS shop, then there is certainly no problem with trusting Fortran. He can also advise on certain things you're unsure of. He's also known to be ethical not to chop less savvy customers.
Possible problems are:
  1. he may not carry certain part(s) you die die want
  2. he's unable to price-match to your expectation subject to his upstream suppliers' pricing for him
But no harm letting him take a look at your list and see if he can do something for you, especially if you want it easy and need someone to assemble for you.
Tiagong he has a chiobu sister. You can offer to go his house pretend to see the build process and self-collect, then same time beo beo see got chiobu sis or not. :s34:
JRRRRR
swee la will do just that. Eh thanks a lot guys I think I will just consult him since I don't really have time to go to SLS again.
MoneyFace =p
OS: Win7 64 oem
IMO Core i5-45xx not as VOM as Core i5-44xx as they only offer slightly higher turbo frequencies but at $12-15 premium. Will go with MSI B85 GAMING anytime over H97 if you don't require M.2 support.
R9-280X do draw more power than competing GTX 770, but heat issue is still manageable with dual fan over PowerColor's solution. GTX 770 comprises a hefty premium over similar R9-280X which dismiss it from recommendations.
Seasonic S12G 550W will be your next best alternative for $15 more.
