Need Advice on Gaming Rig
MakiMaki
Prism X34 not good? Do you have any recommendations for widescreen display then?
Actually what’s your definition of Wide screen? If you are referring to 16:9 aspect ratio then you have got quite a number of options. I’d recommend Acer Predator XB271HU for the best value for its specs, 1440p 165hz OC with g sync at 800++.
If you are referring to ultrawides, which is 21:9 aspect ratio, your best bet will be Acer Predator X34P which is 1440p 120hz OC with g sync at less than $1k at times.
I have never used Prism before but you may refer to the Prism thread to scan through the comments. My cousin did went down to their store and commented that it’s quality is lacking, hence the lower price compared to the other more established brands.
MoneyFace =p
Wow Thanks for the recommendations!
Was planning to get from PC themes as I dun know how to assemble myself haha
All except monitor, RGB accessories and RAM can get from PC Themes but costs about $30-40 more in total. Monitor you can just hoot right away tomorrow morning since you don't really need to lug it together with your PC. I just realise Acer official store on Lazada got $28 off min $550 spending shop coupon. Can further use to offset the monitor price! :s12:
I selected that monitor for you mainly factoring in your desire to play games and also Netflix. 1440p is neither here nor there. Hence 4K is the way to go. With IPS panel and G-Sync to pair up with your RTX 2070 Super, you certainly enjoy the best of both worlds.
dormito
Can't comment on monitor, a lot of monitors on market and sg isn't exactly a place where you can get latest monitor easily either. It is better to source oversea if you looking at high end monitor unless there is a awesome local deals which hopefully someone do keep track and can advise on that.
Anyway, if you are using it for gaming, I would suggest to up your ssd to 1tb.
Games are becoming more space hungry.
If you not oc-ing, no reason to spend much on cooler. I would recommend diverting much of those money on other parts.
Thanks for the advice
Definitely will not be overclocking Dun know how to do it also
So til now not sure if I need a cooler ....
dormito
Thanks for your advice. Will consider changing the display then
dormito
For display to consider : Acer Predator XB271HU vs Acer Predator X34P vs Acer Predator XB321HK 32" 4K 60Hz G-Sync IPS
For RAM: May I know the difference for G.skill Trident Z Neo DDR4-3600 CL18 16GB vs Crucial Ballistix 3200 cl16 2 x 8gb
Dun think I will be getting RGB accessories Do not like too flashy
May I know your opinion regarding the necessity of cooler also?
Thanks!
dormito
So if I bring the RAM to PC themes will they be willing to help assemble ?
dormito
Have to ask a noob question
So how do I download Windows 10 into the new desktop without an OS?
So I just need to buy a digital key to activate?
How come the price difference between a digital key (S$6) vs original windows 10 (S$100 plus) is so much? Digital key not considered original?
Koenig168
You can download and install Windows 10 from here.
https://www.microsoft.com/en-us/software-download/windows10
Digital key to activate.
The $6 keys are definitely not original.
MoneyFace =p
Download ISO from Microsoft and 'burn' the image into a thumbrive. This thumbdrive basically becomes a 'DVD drive with Windows 10 DVD inside'. Run through installation as usual.
MoneyFace =p
It's been a really long time since i patronised them. I guess since you are purchasing majority of stuffs from them they should be ok with that...
MoneyFace =p
Thanks!
Acer Predator XB271HU: Only 1440p which is neither here nor there for Netflix bingeing. Would rather opt PRISM F270i PRO for half the price
Acer Predator X34P: Also only up to 1440p. 21:9 only suitable only if you binge on movies. Also, do note this is an ultra widescreen format. 34" on 21:9 ratio is only equivalent to 27.3" conventional widescreen 16:9 format (same height just elongated). And it is more pricey too. Up to you to consider between 4K/60Hz vs QHD/120Hz...
RAM is mainly for RGB bling bling. Can scale down to normal cheap black Corsair Vengenace if you don't want RGB.
Cooler is for both RGB bling bling and quietness + option to OC in the future. If you feel those are superfluous, can just stick to stock bundled Wraith Stealth cooler.
MakiMaki
Very insightful comments... I think ultimately we need to know what kind of games TS are playing.. if he plays more fps then definitely XB271HU for its high refresh rate + g sync. The 1440p IPS screen should look reasonably well at that distance as well.
If he plays more AAA games then he may consider the ultrawide or 4K screen you suggest... :)
MoneyFace =p
Ryzen 5 3600 + RTX 2070 Super combo is powerful enough to meet adequate fps for all the monitors specs even for AAA games on high-ultra settings. :)
MoneyFace =p
Its a mixed bag. But I'd say RTX 2070 Super has performance advantage over RX 5700 XT in more games. And it's Ray Tracing support and noticeably quieter load noise gives it an edge over RX 5700 XT. Moreover, current price range is rather on the premium side. Buyers may be more willing to topup for these advantages.
MakiMaki
Haha exactly...your recommended setup should bring most games to close to monitor spec hence the deciding factor is the monitor spec and not the cpu itself... 4k 60hz for eye candy AAA games or 1440p 165hz for fps... so it’s still ultimately down to the games TS plays more often.
dormito
Haha usually I play Dota 2 and those MMORPGs games online
Then planning it to use PC to watch Netflix
dormito
Thanks for your advice !!!
Updated my build accordingly :
Main Processor - AMD Ryzen 3600+MSI B450 Tomahawk Max
Graphics Card - GALAX RTX 2070 8GB Super or Nvidia GTX 2070 Super
Memory RAM – Crucial Ballistix 3200 cl16 2 x 8gb
Display - Acer Predator XB321HK 32" 4K 60Hz G-Sync IPS
Storage – ADATA XPG SX8200 Pro 1TB [NVMe M.2 2280]
HDD: Toshiba P300 2TB [7200rpm]
Casing - NXZT H500 chassis
PSU - 550w - 650w EVGA G+ 650W 80+ GOLD 10YRS or Seasonic FOCUS PLUS Gold 750W [80 Plus Gold]
Audio - Onboard Realtek ALC audio
Cooler – Cooler master Hyper 212x PWM or Cryorig H7 Quad Lumi
OS - Windows 10 64bit
Am I missing anything esle ?
