[NEED EXPERTS HELP] Any most bang for bucks lappy can sic , preferably under $1K. But max budget notch more than $1.5K
tian_yibang
Moi ish lappy noob, so quite dunno where to start from specs or function wise
So nong story short, any MS Windows laptops that "worth every cents" for a $1K budget ?
Preferably something notch more bigger than 14" as moi hab space constraints , and at least a 24/512 for futureproof use
Thinking wanna use the SG60V to get a lappy, but the Big 3 major stores and Challenger all dun accept so bopian later need use from GSTCash
Update:
11.11 starting soon , any sexperts here can help sic or offer more/better last min recommendations ?
Or from any seller/official stores that can offer good promo price, other than now-toh Atrix ?
caterham7
is there a specific reasons for 24gb ram?
more ram doesn't mean futureproof
do u use your laptop for gaming? if not, no need $1k, $5oo good enough for basic usage
e.g. acer n100 14-inch, supports type-c charging, no need worry if the laptop charger dies, just use any usb-pd charger
wait for lazada / shopee promo, use vouchers
https://www.lazada.sg/products/pdp-i2185909268-s12497629199.html
https://shopee.sg/Acer-Aspire-Go-14...ICE-1-Year-365-Personal-i.60315503.2334269529
tian_yibang
Acer laptop? Cheap and good?
Hmmmm
Used to hear alot of "negatives" abt this brand , but now dunno if still the same
Tiagong now lappy rams are all soldered on, so worry in future kenot upgrade thus the need for higher
caterham7
Hmmmm
recommend to look at specific model instead of brand
yes acer branding may have negativity, but i have had different experiences with different models. typing this reply on a acer travelmate x3 from 2019, still going strong, touch wood
analogy, within a chicken rice stall, sometimes the roasted chicken rice is nice, but not the hainan chicken rice
whatheheck
got to see which brave soul take over atrix' s place riao..... else won't see much lobang
those brand/authorised stores on S or L may be one of the potential ones
cosmothecat
It’s true
i learned from my mistakes. I bought a laptop, think RAM more important than CPU so load 32GB RAM but CPU opted for a relatively slow CPU
ended up the laptop always lag and freeze when there are heavy processing loads. Then just put one side no use, very annoying to use a slow laptop
so ya. It is a balance. 16GB ram is good enough for most tasks but CPU must buy a relatively fast one
cosmothecat
Acer is hit or miss
most Acers I bought were ok but got one laptop the glue used to glue the screen started to ooze out after 1.5 years
NintendoSwitch
Lenovo ThinkPad E14 Gen 6 (AMD) SG$1,502.75 GST incl. and free delivery at Lenovo website.
  • Memory: 32 GB DDR5-4800MT/s (SODIMM) - (2 x 16 GB)Edit
  • First Solid State Drive: 512 GB SSD M.2 2242 PCIe Gen4 TLC OpalEdit
  • Processor: AMD Ryzen™ 5 7535HS Processor (3.30 GHz up to 4.55 GHz)Edit
  • Operating System: Windows 11 Home 64Edit
  • Operating System Language: Windows 11 Home 64 English
  • Microsoft Productivity Software: No Microsoft OfficeEdit
  • Display: 14" WUXGA (1920 x 1200), IPS, Anti-Glare, Non-Touch, 45%NTSC, 300 nits, 60HzEdit
  • Graphic Card: Integrated Graphics
  • Camera: 720P HD RGB with Microphone and Privacy ShutterEdit
  • Color: Graphite Black
  • Base Cover Material: AluminumEdit
  • Wireless: Realtek Wi-Fi 6 RTL8852BE 2x2 AX & Bluetooth® 5.1 or aboveEdit
  • Ethernet: Wired Ethernet
  • Fingerprint Reader: No Fingerprint ReaderEdit
  • Keyboard: Backlit, Black - English (US)
  • Battery: 3 Cell Rechargeable Li-ion 47WhEdit
  • Power Cord: 65W USB-C Low Cost 90% PCC 3pin AC Adapter - UK
  • Warranty: 1 Year Courier or Carry-in
