Need help for a case and cooler~
Anariga
I just acquired the following items from the 11.11 to BF to CM frenzy. Left case and cooler. hoping to hoot in 12.12.
CPU+MOBO: i7 6700k+asus z170a
RAM:corsair vengeance lpx 2x8gb 3000mhz
PSU:EVGA G2 650w
GPU: ZOTAC GTX 1070
HDD:seagate 3TB
SSD:samsung 500gb evo
all in all managed to save alot and got good deals!
Hope all the lao jiaos here recommend some case and cooler.
Krabs.
according to user reviews at amazon , seagate 3tb have higher failure rate than 2tb 4tb
singupingu
h100i gtx or v2? v2 is updated version of h100i gtx right?
Correct. Or can get h110i which is even newer lol. All depend on budget and which look more appealing. There all work about the same and you won't notice a difference unless you consistently keep checking the temp all the way between two Cpu running two different aio :s22:
prefer air cooler to aio. is the hyper 212 evo still viable nowadays?
Still applicable. Many still buy this for oc using air cooler. Personally prefer aio for sleek look and led light. Hahaha. But air cooler work as fine too.
Sent from Overpowered Phone Mark III using GAGT
kaixax555
hmm now is 212x liao
casing up to you, a cheap and nice case is the Tecware Alpha
Krabs.
212x local price cost 50% more than 212evo from amazon , improvement only 1 degree celcius
kurui_
Case
Need USB 2.0 : R5
Don't need USB 2.0 : define C or S
Cooler: cryorig r1
Noctua d15 color not nice.
xboxer
Prepare to break a leg to arm it with their new ML series fans. :s12: :s12:
Anariga
No h ways can get. SLS shop got sells them.
Wa i go lazada see see around 70. Im able to get it for 29usd after discount from amazon and ship to forwarder. Might be cheaper.
Cpu cooler usually will spoil anot? Later i buy from amazon lemon or spoiled de then cpu gg.
kurui_
any other difference between define c/s and r5?
Difference to define S
R5:
-Have hdd cages (removable)
-Have optical drive cages (removable)
-one lesser front case fan
-window version's window smaller
-have front door than can swing open (you've to snap open the front cover of C and S to mount fans or clean dust filter)
-have fan speed controller (simple one)
C:
-shorter in length
-back fan mounting only can mount 120mm case fan.
-have psu shroud
-Dust filter for top intake (finally!)
Not sure if I missed out anything
ken_lzj
dust filter for top intake is useful but defeats the purpose of noise containment right?
psu shroud is nice but since the window of R5 is smaller, we won't see the psu from the side?
well i am trying to decide which case to buy...R5 seems to be the best but from the reviews i read, its cooling really not as good and not enough when OC..but others are a bit noisy...just cant seem to find a good balance between cooling and noise..........
R5:
C:
-shorter in length
-have psu shroud
