Need help for a case and cooler~
ken_lzj
hi, where did you see 28usd noctua in amazon? those i found are much more ex leh....in the end i bought cooler master hyper d92...
Wa i go lazada see see around 70. Im able to get it for 29usd after discount from amazon and ship to forwarder. Might be cheaper.
Cpu cooler usually will spoil anot? Later i buy from amazon lemon or spoiled de then cpu gg.
Krabs.
just get the 212evo from amazon la ... USD 28 = 41.20 sing dollars ..... no need care about what the forwarder charge you .... much cheaper than $69 212x local price
either way ... these coolers are too small to max overclock 6700k
kurui_
dust filter for top intake is useful but defeats the purpose of noise containment right?
psu shroud is nice but since the window of R5 is smaller, we won't see the psu from the side?
well i am trying to decide which case to buy...R5 seems to be the best but from the reviews i read, its cooling really not as good and not enough when OC..but others are a bit noisy...just cant seem to find a good balance between cooling and noise..........
It' is an option to put the dust filter, if you decide to open up and use your top intake outlet. Default is the noise dampening material.
If you want maximum noise dampening, should chose their non windowed versions.
jayz89
ohh thanks. but i see this Cryorig h7 does not ship to singapore..maybe temporarily out of stock in amazon's warehouse
Cryorig doesnt ship to sg from amazon..
i tried contacting them they told me cos sg got retailer :vijayadmin:
ken_lzj
yeah i know, i meant if we open up the top panel and install fans, its noise level would probably be comparable to those not designed for quietness
kurui_
Well yeah, you're not mounting radiator on top, most probably you'll not need to open the top panels.
The air flow from 3 intake front fans and a rear exhaust fan is good enough for me.
ZrE0_Cha0s
but this is kinda some what negative air flow though. 3 in 1 out. (yes even though 2 in is cooling the radiator. )
kurui_
I'm sorry to confuse.
I only got 4 fans. 3 default fd fan in 1 noctua fan out. Using noctua-d15 to cool my CPU, no mount radiator at top. Haha
The air filter is good news for those who likes the design and wants to fix radiator at the top.
The psu shroud also is up to personal taste, I feel.
