need help for COD Ghost!
legolaslee
Hi guys, below is the specs for my CPU. Im quite a noob in this, may I ask, what do I need to enable my com to play COD Ghost? and what type of RAM should I get which matches my motherboard?
Motherboard: Intel(R) Core(TM)2 Duo CPU E6750 @ 2.66GHz
RAM: 2GB
OS: Microsoft Windows 7 Ultimate Edition Service Pack 1 (build 7601), 32-bit
Video card: AMD Radeon HD 5700 Series
yusoffb01
You should add another 2gb ram. You should be able to play on some med settings @1080p
legolaslee
Monitor resolution 1440 x 900. I don't mind low settings and adding another 2gb. But when I tried to open the game it says failed to start game. So I'm wondering is it because of my specs being not up to date ?
legolaslee
just installed and auto patch to the latest i believe. could it be because im still using 2gb ram now? and i should install up to 4gb at least for this game? if so, what kind of ram should i get?
FinalTidus
RAM: 2GB
Bro your rig uses DDR2 rams. make sure you have at least 4gb rams for your game to be smooth on win 7 64 bit.
your pc should be able to play at low to med settings. you can try to overclock your CPU and gfx card for more performance.
My 2C
legolaslee
possible to play on win7 32 bit? cos I cannot even open the game.
so I should buy 2 x 2 GB DDR2 ram is that correct? anyway I wanna upgrade the RAM since long time ago lol. any recommended brands?
FinalTidus
best if 2 x 2gb. 32 bit os is fine if you are maxing out your RAM at 4gb. cos the os will recognize only 3.5gb of RAM.
get any cheapest value rams will Do like gskIll or Kingston.
hlots123
from online posts, ghosts still only runs on 64bit os. even if they patched the 6gb requiremt to 4gb, they didn't create any new 32bit game binary.
legolaslee
yea i saw those posts also.means theres no way to play cod ghost on my 32 bit os? and i will need to get 64 bit os?
legolaslee
just to check, if i were to upgrade my OS to windows 7 ultimate 64 bit, can I insert 2 x 2gb DDR3 RAM? or still DDR2 RAM?
shadow84
All depends on ur mobo... if it is very old, it can only accept DDR2. If it is new, it can only accept DDR3.
I feel it is a waste to put wins7 64-bit on such an old mobo/cpu. Go get a new CPU, mobo and ram and install wins7. Otherwise, you are just wasting it.
legolaslee
Thanks for the quick reply.
If I were to go for a new rig, is there any thing below that i can reuse? budget <$1000. no need monitor and OS. DVD drive i believe can reuse. if mostly cannot reuse then i might just get everything new and sell away this current rig.
RAM: 2GB
Storage: samsung hd321kj ata device 300GB
Casing: Cooler Master Centurion 5
PSU: Cooler Master Extreme Power Plus 550W
Audio: Im using Altec Lansing VS4121, which soundcard should i get?
