Need help for gaming pc
xnebuuuu
I have a budget of 1.5k,hoping to have an above average pc for playing league of legends with good fps,l4d2,minecraft and rpg games. Please suggest me essential parts including monitor,OS,which shop to buy the parts and where to find shops able to build it for me. Planning to overclock the pc too. If its within the budget , i would like a cool LED casing . Thanks in advance !!
x3illuminate
buy @mynextcomonline.com
they offer free delivery also service is good ;-)
Should look something like this
Remainder can use to hoot OS,monitor,etc.
SLS should have better combo deals
This site like convenient only lol
royfrosty
1.5k to oc a bit hard. You probably need a good cooler to go with it and a good speed ram. So it should be out of the question. Best option will be non oc.
For 1.5k
MSI B85m G43 + i5-4570 ~ $356
Kingston Value Ram 8gb ~ $81
WD Blue 1tb ~ $81
Plextor m5s 128gb ~ $139
Palit GTX760 2gb + FSP Raider 550W ~ $399
Sharkoon MS140 ~ $54
Windows 7 Home Premium OEM ~ $115
LG IPS234V IPS monitor ~ $228 (Best Buy Shop beside Fuwell)
Samsung ODD ~ $21 (Optional)
Total $1474 Buy at tradepac, DIY.
xnebuuuu
Is msi z87 g65gaming not a good mobo? Looks quite good yet why nobody is suggesting it ?
royfrosty
That mobo is good. The thing is you may not fit in the budget at all. A MSI z87 gd65 + i5-4670k already $507. That is 1/3 of your budget gone. Yet you need to set aside your monitor and os.
xnebuuuu
If i can increase my budget to $2000 what other parts should i improve for better fps ?
royfrosty
The most can up to a gtx770. Cheapest is Leadtek gtx 770 2gb ~ $585
Else is an Gigabyte gtx770 2gb ~ $665.
And you need a 600w PSU.
Seasonic m12ii 620w ~ $118
xnebuuuu
Is the zalman z11 plus casing good ? If so, how many fans and cpu/gpu coolers should i buy ?
