need help for my com rig
alvinlight
Hi guys, I decided to get a new com but I'm not good at those hardware. I wanna get a mid end com just in case i wanna play games that needs high specs. Please give me some comments as I'm considering the specs below:
Intel Core i5 4670 & Gigabyte H87-D3H
Corsair 1600 CL11 2x4gb or Kingston 8gb single piece (any difference?)
Powercolour HD7850 2gb or Palit gtx650 2gb ddr5
plextor m5s 128gb ssd
Samsung oem drive
ard midi r2
using back:
wd blue 1tb
seasonic m12II 520w(any problem if I use back?)
TIA
ryuxdragonx
Samsung oem drive
ard midi r2
using back:
wd blue 1tb
TIA
i5 4570 and a B series board will do. You only need H if you plan to do raid.
For ram I would always go for 2x4gb kits over a single ram.
Do advise on budget and I'm sure we can give you a suitable build.
Jian19
i5-4570 + Msi b85m g43 ~ $356
Kingston 8gb ddr3 ~ $98
Plextor m5s 128gb ~ $130
Zotac gtx760 amp ~ $360
Samsung oem drive ~ $21
Sharkoon t28 ~ $84
Total ~ $1049 buy and DIY @ tradepac ask for discount....if still got budget can get Gigabyte 280x @ $420 ~ (if got stock)
royfrosty
Samsung oem drive
ard midi r2
using back:
wd blue 1tb
TIA
I'm assuming your budget is around 1.1k
Go for a b85 board if you are not going to do raid. You can go for single piece ram. Doesn't make much of a difference. You will not be able to feel it.
MSI b85m g43 + i5-4570 ~ $356
Crucial 8gb 1600mhz ~ $89
Reuse HDD
Plextor m5s 128gb ~ $135
Zotac gtx760 2gb ref card + superflower hx500 500w 80+ gold ~ $399
Samsung odd ~ $21
Fractal design arc midi ~ $129
Total ~ $1129
alvinlight
my budget is around 1k~1.1k
ok I will get b85 board. so I can use back my old psu ya?
instead of Zotac gtx760, can I get gigabyte r9 270x ~$289?
I intend to get them to fix the com for me, which shop shd I go to?
royfrosty
Go to PC themes but you will pay slightly more.
If you want you can go try tradepac. But be there when they fixing for you.
you want r9 270x is slightly decreasing in performance. If you dont mind then can ba.
The bundle for zotac is inclusive with a PSU.
theuser
Mynextcom also not bad, they fix up for you also
PCthemes also can.
tradepac , if you can old bird
alvinlight
so tradepac only for old bird? i check the price of tradepac with the others and tradepac prices are lower. how about bizgram?
anyway do they charge for fixing up the com or only free if buy whole setup?
AnTiLooP
if you have basics on setting up a com, take your time and attempt to do it.
nothing beats doing it yourself at times.
theuser
you have to know how to lower the price at tradepac.
bargain skills.
as for your question, mynextcom provide fix up service for your pc ($30). i think if you buy all parts from them you can request them to build for you for free. (you can try whatsapp them)
just visit mynextcomonline.com all details over there
betaunknown
bargain skills.
Tradepac must check the items and conditions also.
Examples include:
When buying RAM, do not just check the packaging capacity and speed ratings, check the RAM module itself. What is on the packaging may not be what's inside. If you leave the shop before checking, GLHF to you.
Check whether the parts are used. Sometimes customers that go back to the shop to do exchange may get a replacement from TradePac. But TradePac won't return the alleged "faulty" item back to distributor for RMA. If they test and it's presumed working, they might just sell it off again.
Hua_Hui
Examples include:
wow tradepac so shady in doing business de ah, might just shop just mynextcom or pcthemes to have a peace of mind...
