Need help for new PC
FreeRoon
Hi, a IT noob here, but i would like to ask if there is any store is SIM LIM that provides D.I.Y com that can use monthly installment? sorry poor kid here :( . i prefer to be gaming specs.
Budget is around $1900 - $2000
I do not need a monitor, keyboard and mouse
Thanks in advance!!!!
wtfwfs
Eh sorry c wrong....
Your budget agaragar how much...
Play semo games?
Got any brand preference or as long fast good, can play your games and within budget u ok le?
Wait for all the shifu recommend
FreeRoon
At 1st wanted intel processor but seem like that is a lot of other brands that is more cost efficient and better performance than Intel.
Graphics card i looking at nvida Geforce GTX 750. or is there some brands that are better or cheaper?
i hope to play games like BF4 on high end mode.
Budget if possible $1800- $2000
Keyboard and mouse don't need.
Monitor hopefully no need as well.
Therefore Budget purely on CPU only.
Thanks in advance to all the shifu !!!!
FreeRoon
Btw how much would
Nvidia Geforce GTX780ti
Nvidia Geforce Titan
Nvidia Geforce Titian Black
cost. and which is more cost efficient.
Sorry for asking so much cuz i am really noob is all this :(
wtfwfs
Ndivia I no experience....
Best wait for roy n shadow84 to lai gai xiao...
Jian19 to give u suggestions..
shadow84
Btw how much would
Half of ur budget le.... if gaming on 1080p, gtx 780 or r9 290 more than enough and slightly futureproofed for upcoming games.
royfrosty
You wont need a 780ti onwards for a 1080p monitor.
From what i can see from all your post, you really know nothing much. (sorry if it sounds harsh, pardon for my insensitivity)
If nvidia is what you want
Msi b85 g43 gaming + i5-4570 ~ $384
Gskills ripjaws 1600mhz 2x4gb kit ~ $113
WD blue 1tb ~ $75
Crucial m500 240gb ~ $185 or ($155 from amazon)
Msi gtx780 3gb twin frozr ~ $735
Seaaonic g650 650w 80+ gold semi modular psu ~ $135
Corsair Obsidian 450D ~ $169
Samsung ODD ~ $21
Windows 7 home premium 64bit oem ~ $110
Total ~ $1927. Buy at tradepac. Diy
Optional
Dell s2340L 23inch eIPS panel ~ $219 (just in case your monitor is not even 1080p)
Msi r9 290 4gb twin frozr ~ $688 (a competitive model against the 780)
Fractal design arc midi ~ $129 (if you wanna save cost)
shadow84
There are only a handful which accepts installments such as cybermind, but by doing so, they wun give much discount or mayb even none.
U poor kid still gt budget of $2000?
Jian19
Maybe papa card ? :o 1.3k ~
i5-4570 + Asrock b85 killer ~ $357
Crucial 8gb ddr3 ~ $90
Crucial m500 120gb ssd ~ $115
Wd blue 1tb ~ $74
Leadtek gtx760 OC ~ $345
Samsung oem drive ~ $21
Fsp aurum s 500w ~ $86
Corsair Carbide Spec-02 ~ $84
Win7 64 oem ~ $110
$1282 buy and DIY @ tradepac. If not sure ho to DIY can bring to gs shop ask him help u assemble @ a fee.
User-name
if want get r9 290 on 1080p it will produce screen tearing so be ready to turn on v-sync
shadow84
It depends on what games... For dota2, then need to turn on. If its metro LL, then no need coz fps is around 40-50 nia. Even for BF4, once u crank up to 4x MSAA and SSBO enabled, FPS is around 60-70 liao, with occasional drops.
He say he wanna play BF4, so in ultra, 4xMSAA and HSBO enabled, sure around 60fps range de.
User-name
I play arma 3 keep screen tearing until need to turn on v-sync maybe arma 3 is more on cpu intense
shadow84
It depends on the upper limit of your monitor. Some 60hz monitors can tahan up to 70fps then maybe start to show some minor tearing le.
FreeRoon
Hi, thanks for all the advice!
Sorry, But i still have a few doubts that need to be clarify.
For the Ram if i want to go for 16GB. should i go for the Corsair Veng Pro 2400C11 or G.Skill Trident-X 2400 C11 both 2 x 8GB.
FreeRoon
Oh ya and also if i want to get i7 is it very stupid?
and the graphic card what is the different in the R9 and GTX780? is it in terms of quality or duration?
Sorry Bros, for all the inconvenience caused!!!! :(
hengheng220
Yes i7 for gaming currently is abit stupid since you won't need the hyperthreading in today's gaming and I7 is abit more expensive than the I5 by around $100. The difference between r9 290 and 780 are brands and prices. They both perform quite similar
Ram just stick with the crucial 8gb Jian recommened cause gaming won't need until 16gb. In addtion, you can't see the performance difference between the 1600mhz and 2400mhz, so might as well get the cheaper one
FreeRoon
Thanks for all the advice!!! :)
for the Ram if i go for Corsair is also ok right? as in 8GB
