Need help in Building New Computer Rig
caleb.seah
Hi!
I need to build a new computer. With a budget of $800 without OS, monitor and kb n mouse. Main use of the computer will be to do web surfing and sometimes adobe photoshop(not high usage).
May want to be able to display up to 3 screen. may be able to play battlefield 4.
any recommendation?
Thanks!
royfrosty
Hi!
any recommendation?
Thanks!
$800 like not enough. If you intend to play 3 screens for bf4.
Reconsider your budget.
jiaweiii
asrock b75m dgs + i5 3350p ~ $ 271
Crucial 8gb 1600mhz value ram ~ $ 90
WD Blue 1TB ~ $ 80
Powercolor 7870 2gb ghz edition ~ $ 250
Cm311 + fsp hexa 500w ~ $ 105
Samsung ODD ~ $ 21
Jian19
i5-3350p Asrock b75m dgs ~ $271
Crucial 8gb ddr3 ~ $90
Wd blue 1tb ~ $78
PC 7870 ~ $241
Superflower hx 500 ~ $89
CM n200 ~ $52
$821 buy and DIY @ tradepac ask for discount
Can power up 3 screen, can play bf4 (high settings) , can handle photoshop
But can't play bf4 on 3 screen :o
caleb.seah
Hi! Thanks a lot for the recommendation guys...
Yup i need 3 monitor to surf internet and not to play bf4.
royfrosty
7870 still not enough to power 3 screens unless you go for the 7870 eyefinity edition which will be half your budget gone.
Have tried the ghz edition. It did managed to pull thru 3 monitors just for internet purposes and other work purposes. But it will be a bit sluggish if you dont mind.
But on the other hand the powercolor 7870 myst can tahan 3 monitors.
caleb.seah
and how much is this 7870 myst? is it way above my budget if replace 7870
royfrosty
Myst eol le. But might be able to find in sls. Is at $300 flat.
Mclairs83
get a motherboard that support onboard gfx and insert another gfx card.
that will support 2 output on gfx and 1 x output onboard.
MoneyFace =p
i also run 3
vga/dvi/hdmi
on a single gfx card hor
meanin?
on board gfx card nothin plugin
plug in all 3 ports of a good xternal pci-e gfx card
We all aware your configuration will work, but our concern here points to the workability of outputting both IGP AND discrete graphics card to separate monitors simultaneously. :o
MoneyFace =p
https://communities.intel.com/thread/42192
I'm running 3 monitors occasionally with my rig..
Thanks for the insight. Simultaneous integrated/discrete graphics output wouldn't work for me till even for my current Sandy Bridge system as i kept getting graphics controller conflict and running into safe mode. Therefore i had this thinking it will never work since heterogeneous support mainly works for discrete graphics AFAIK. :o
caleb.seah
So what's the recommendation cause i'm kinda noob in computer stuff haha... thanks for advice in advance... :)
MoneyFace =p
Sluggish as in not enough VRAM even for normal usage? :s11:
