Need help in Building New Computer Rig
royfrosty
Sluggish as in not enough VRAM even for normal usage? :s11:
Not sure leh. Despite 3 monitors doing just casual work the 2gb is gonna hit max.
last tried, the vram usage quite high. floating around 1.7gb already.
Either the eyefinity model or a faster gpu would do the trick. Cause ive tried myst it was fine.
There is a reason why the eyefinity 2gb model ones are able to support this 3 monitors and still remain usable. It was design for it. And there is a price to pay for it.
royfrosty
What i suggest lah, best is up the budget by a bit more. 7870 myst would do the job.
I wont wanna recommend a normal 7870 and wait you experience something not nice and is not gonna be what you want.
So i would just go ahead and recommend what you really need.
Asrock b75m dgs + i5-3350p ~ $271
Crucial 8gb 1600mhz Value Ram ~ $89
WD Blue 1tb ~ $77
Powercolor Myst 2gb ~ $300
CM311 + FSP Hexa 500w ~ $105
Total ~ $842 Buy at tradepac. DIY.
This would be able to run 3 monitors smoothly and able to game bf4 on single monitor.
If you got a bit more to spare can always try 7950 at $318 Powercolor.
MoneyFace =p
Could it be something else sucking away VRAM running in the background then? I really cannot believe 5760 x 1080 @ 60 Hz needs so much VRAM to draw...
Also, there are other eyefinity cards with even lesser VRAM (HD 7770, HD 6450) but they still run those monitors fine no?
MoneyFace =p
So what's the recommendation cause i'm kinda noob in computer stuff haha... thanks for advice in advance... :)
Mine would be very similar to theirs... :o
CPU+MB: Intel Core i5-3350P + ASRock B75M-DGS @ $271
RAM: Crucial DDR3-1600 CL11 4GB X2 @ $90
GPU: PowerColor R9-270 2GB @ $241
HDD: Western Digital Blue 1TB @ $76
ODD: Samsung 24X CD/DVD Writer [OEM] @ $21
CASE+PSU: Cooler Master Elite 311 + FSP Hexa 500W [80 Plus] @ $105
Total: $804
Buy + Build from Tradepac, #05-19.
Store Bundle
royfrosty
Also, there are other eyefinity cards with even lesser VRAM but they still run those monitors fine no?
Dont think so leh. Cause it was a fresh install OS. And with all the updates done. But still cant perform well with it. So he went back to change for a myst edition instead and top the difference.
royfrosty
Would it be possible that vram are used when opening a flash game on browser?
royfrosty
Possible, if using chrome can check through Chrome Task Manager (Shift + Esc in Chrome).
Then can conclude that the 2gb vram might be sufficient ba. Just that if open any tabs with flash base content the 2gb vram will no be sufficient enough. Or just hit almost max.
caleb.seah
Total: $804
Store Bundle
Went down tradepac today...
They don't have fsp Hexa power supply and powercolor r9 270 le...
They suggested gigabyte instead...
MoneyFace =p
Keep insisting for them, look around the store for sign of any stock. Try walking away until they grab you back desperately. If really don't have, then consider getting FSP Raider 450W @ $75 or Super Flower Golden Green HX-500W @ $88, Sharkoon MS140 @ $52 and PowerColor HD 7870 2GB OC, R9-270X 2GB.
caleb.seah
Hi.
What's the difference between 7870 & R09 270x?
They also mentioned that 3350 is sold out and recommended 3330. Is that better?
caleb.seah
Went down today, they recommended to me AMD processors (Asus A85XM and 6790K)?
What are your thoughts about it?
Because the price he quoted for this:
CPU+MB: Intel Core i5-4570 + ASRock H81-MD4S
Total at $875.
Not sure worth it a not to get intel or AMD(Price lower significantly)
hengheng220
Total at $875.
how much is the price diff?
Felfirez
Total at $875.
Nope, don't get the AMD system.
3330 more expensive than 3350p, performance difference negligible. You can bargain with the guy. Surely can get nearer to $800.
caleb.seah
He mentioned that he do not have 3350p already as it is the 3rd generation.
That's why he recommended the 4570. what do u think about it ?
Why don't get AMD leh? any reasons?
