Need help in cpu system in WEST!!!
ProGamer84
Hi, is anyone stay taman jurong know well on software troubleshoot? Current i having is problem on my windows 10. i always shut down my pc. After my cpu completely power off, like all the fans and like are off. about 5secs will auto boot up which auto turn on. I tried to google and youtube on this problem and follow the setting like turn on fast startup i was unclicked also. But still having the some problem..
If someone kindness can able to help me. a simple treat on me. I am stay at taman jurong.
spiky0180
Check your wake on lan and network adapter settings? Uncheck allow device to wake computer option.
hlots123
try enable "ErP Ready" in uefi bios
Advanced> APM Config> ErP Ready> change from "Disabled" to "Enabled (S4+S5)"
if no change, u can change it back to default Disabled
commach
Did you trued hlots123's suggestion?
If software problem, can use Teamviewer remote access to troubleshoot, you don't need site support for software problem.
For a start, rightclick ThisPC>properties>Advanced System settings>Startup and Recovery>Settings>Uncheck Automatically Restart (under system failure)
Wait for BSOD (if any) and update us the stop error code of the BSOD.
ProGamer84
Haha.. right i still trying to go in bios setup wat given by hlot123 suggestion. And ur setting I tried same..
Yes i use teamviewer..
yusoffb01
My computer sometimes randomly switch on.
I changed every part already, from motherboard, cpu, psu, ram, casing, operating system and it still happen.
In the end, I make it a habit to switch off the PSU switch, problem solved!
ProGamer84
Yes this is what happen I do this for couples of weeks. Just very irritated when I forget to switch off the plug on my wall. Then I got to wait again.. so best is I can get someone to help me solve this damn problem..
sacar101
Check if that's any "REMOTE WAKE UP" setting in BIOS, if so disable it and see it works or not.
Firegear
Hi,
Test 1) remove lan cable. Go bios load default settings.
Test 2) check your motherboard front header pin for the power button is it not short circuit. You can remove check your motherboard manual how to remove.
Test 3) check your motherboard 24pin or 8pin is the wired connect or faulty.
Don't ask me why I know.
Sent from Samsung SM-N910G using GAGT
ProGamer84
Hi,
thanks for ur info.. But ur following info which i not very sure how to troubleshoot. That why i posting see anyone stay at taman jurong know how to solve this problem or not.
Tycobb
got this guy at jurong west who fixes computers.
u go carousell find this user "icelabz"
