Need help in cpu system in WEST!!!
LiLAsN
where to find the setting?
1) Try this. Disconnect your Lan cable and then shut down your PC. If you are completely disconnected from the router and your PC doesn't boot up, then we can be sure that it was caused by a 'Wake-on-Lan' setting still turned on somewhere.
2) Worst comes to worst, you might have made a careless mistake of putting your power button to restart your PC instead of shutting it down or putting your PC to sleep or put your PC in Hibernation.
3) If options 1 & 2 still makes your PC boot up, then it could also be caused by either your mouse or keyboard being too sensitive. try taking out the USB for one of them to see if either with only the mouse or keyboard attached, the PC still turns on. If it is maybe with the keyboard, try switching to another USB port on your PC. Then you could also try pressing all the keys to make sure that they are all working. It could just be a case of a sensitive key that is responding for the littlest of vibrations.
hlots123
when u set ErP Ready to Enabled, wake on lan & PME event wake up etc will be disabled too
the lan port will not have light when u shutdown
to enter uefi settings, start tapping DEL key during power on, especially during asus screen if u have it (before windows loading screen)
ProGamer84
noted. i will try first step later on... rest will try tmr...
for this later i restart i go to bio and check.
cscs3
Hi, is anyone stay taman jurong know well on software troubleshoot? Current i having is problem on my windows 10. i always shut down my pc. After my cpu completely power off, like all the fans and like are off. about 5secs will auto boot up which auto turn on. I tried to google and youtube on this problem and follow the setting like turn on fast startup i was unclicked also. But still having the some problem..
If someone kindness can able to help me. a simple treat on me. I am stay at taman jurong.
Try this:
1. Windows key, type "power option" (without ")
2. click on the power option
3. click on "choose what the power button do"
4. click "change setting that are currently unavailable"
5. uncheck "turn on fast startup...."
6. save change and restart your pc, then shtudown to see if problem happen again.
ProGamer84
Try this:
Thanks for the info. I tried before same..
