b3njaminlee
- Jan 11, 2011
It should be fine, but down the road psu might not be what it's when first use. I also changing to from 7970 to 390 planning to change psu also
Yup, if not OCing your com just down size your mobo cpu, psu also bit much but if U gonna SLI then 700> would be safer.
980ti would be lovely compare to 970 SLI which could be a hassle.
And be wary of size of case when getting a bigger card GPU
bro, just to check with you on pros n cons on gddr5 vs hbm as i came across them when i read on r9 fury vs gtx 980ti
this is my recommendation
the mobo h170 does it support nvme ssd? sry im new to this nvme
http://www.asus.com/sg/Motherboards/H170-PRO-GAMING/specifications/
but no support for sli only crossfire
http://www.asus.com/sg/Motherboards/Z170-PRO-GAMING/specifications/
support sli and crossfire
get any z170 for sli support if u want
or get h170 but no sli support
both support m.2 ssd
that means i need get z170 series as i read fury x might not be good now maybe due to software issue as compare to nvidia de
but for motherboard i still prefer Asus board
i like both amd and nvidia gpu cardbut for motherboard i still prefer Asus board
for me Asus(/eɪˈsuːs/) z170 pro gaming is good because it can support crossfire and sli and the board can support cpu overclock if only u want to overclock it in future
i5 6600k+ asus z170 pro gaming will be a good combo depend on ur budget
or get any z170 support sli board any brand that is cheapest and good...some dont support sli eg Asus Z170-k.....MSI Z170 PC Mate
so far sls sell B series,H series and Z series and ROG maximus series
H and B series support Crossifre
Z and ROG maximus series most support sli and crossfire
