Need help on Samsung SSD
djr81
Hi all,
not very familiar with SSD, any bro can help
My main OS SSD is working fine and fast.
I add in a Samsung EVO SSD 500gb as 2nd harddisk and everything seem like not normal to me. The serial no look funny and the system information all is NA.
is this normal?
Tks in advance.
wacko
have you created a new volume under Disk Management for the new drive?
djr81
everything done liao leh.. i do like normal harddisk. format and can use liao.
but at samsung apps. the system information show the 3 items is NA and the test speed is so slow as compare to the main OS HD.
don't know wats wrong.
jtjt00
I don't see a 500GB SSD in the magician app, more like 250GB one on SATAII connection. Is this SSD installed on the desktop with spec on the right?
djr81
Bios
Samsung Magician non os hd
OS HD
anyone can help?
Tks:s12:
hlots123
any diff with latest version samsung magician?
btw wat gigabyte board?
Kusanagi
have you checked if your sata port 2 is Marvell chip or Intel?
I suggest you change your storage hdd to the sata port 2 and change your ssd to sata 1 port
djr81
Main OS i put at Sata port 1 and the new ssd as Sata port 2..
wah lao..thought is easy just pnp..knn maybe computer old liao =(
ClementChong
Your BIOS show OS SSD is in port 0, your 2TB HDD at port 1 and your new SSD at port 2.
Swap your HDD port with your new SSD port, for sandy bridge/ivy bridge only port 0 and port 1 is 6Gbps.
djr81
So if got 3 or more SSD no use liao ah.. cuz 1 and 2 port is 6gbps right? or newer support more 6gbps?
:s11:
yusoffb01
:s11:
Even on sata2 still got use can write about 350MB/s
Most ssd that use tlc, their real write speed drops to 350MB/s after 10GB. Benchmark dont write so much so u see 550MB/s
wacko
list your full system specs, if you expect proper troubleshooting advice.
djr81
ya later go home can list...
old liao seldom play hardwarezone liao.. see my spec on the right hand side... :s22: also no time to update :s13:
ZrE0_Cha0s
I wonder what this TS for now though from asking of no info of the SSD to whats the speed limitation on the SSD :s22:
