need help pls on reuseable item
shadow84
Oh ok.. Thanks.
Saw them.. It look nice.
This only 2fan vs arc midi 3fan (hope I get this right)
Will that make a big different on the cooling part?
It doesnt really matter since both given fans aint that great. That is just the amount of free fans they give.
Arc midi has support for 7 fans, whereas BD28 has support for 5 fans. U can always buy better fans to put into ur case.
for-kel
I wun really recommend OCZ ssd... At least get plextor m6s 128gb at $105. More reliable.
U can consider Sharkoon BD28. If u can bargain, do it at Tradepac. And then bring all items to #02-32 to ask Nigel to help u assemble for some kopi $$$.
1 more way to save $$$ is to climb mountain for OS...
Pay $30+ more for a MSI B85-G41 PC Mate and jam all your RAM in there.
I see.
Ok thanks. Now
After everything added up around 1070..
Will go look for them. Thanks so much.
for-kel
this should be the build I going for is it ok? or can change other item.
CPU+ Mobo: MSI b85m-g43 + i5 4460 (363)
GPU: MSI R9 280 3gb (339)
( I know lazada.com selling the GPU cheaper) bt for some reason, I wan to get all at the same place
SSD: Plextor M6S 128gb (109)
HDD: WESTERN.D 1TB BLUE (72)
PSU: SEASONIC S12II-Non MODULAR 620W (99)
Case: sharkoon DB28 (blue) (79)
OS: WINDOWS 7 HOME PREM (120)
RAM :G.skill value ram 8gb (2*4) (108)
total dmg around 1289
did I miss out anything?
Alternative X
Since you are willing to spend more $$$, spend $10 more and get a Superflower HX 600 80+ Gold PSU for $109. Other than that, your build is fine. However, the MSI B85-G43 has 4 RAM slots and you can just buy a 4GB stick of RAM and install your 3 sticks of RAM into the motherboard and save $50 in the process.
for-kel
thanks alternativeX and other who help,
i got my Rig today at pc thems
CPU+ Mobo: MSI b85-g43 (gaming) + i5 4460
GPU: MSI gtx760 (r9 280 no stock) 280x too ex :(
Case: sharkoon t28
RAM :G.skill ripjew 2*4 8ge ram
total :1335
shadow84
Case: sharkoon t28
total :1335
The pricing for 760 in SG isnt good... 280 beats 760 and 280x is even better than 280.
O well, since u buy le, den dun think too much abt it and just use.
Dun have powercolour r9 280? Should be selling at $339 or so.
for-kel
hee i didnt ask about pwercolour 280,
i ask for somthing close to 280 than they recommend this.
ya buy le dont think too much must enjoy now..
haha
oh ya i think my tv monitors cant support 1080. when i change the setting
it become vy bad.. (not sharp at all) :s22::s22: have to use 1360 x 760 better
shadow84
haha
Hw big is ur tv? Even if its 1080p, by going bigger in tv size, the picture will look more pixelated (blurry).
Check ur content also, make sure its a good 1080p video.
for-kel
cant remember how big is it (maybe around 21-22")
not gaming or anything just normal, once change to 1080 it look ugly liao
shadow84
That is monitor, no tv...
That is weird... try playing with settings or try with different monitor.
for-kel
i remember this a tv leh.. ( monitor can play tv channel?)
ya i try see how ( bt this vy long liao 4-5year? )
