need help to build new pc
harky
most likely my mb is gg.
i need help on mb brand.
isit recommend to buy i5 3400, ddr4? or buy AMD 7600?
any recommend?
mainly can use for utube, use adobe photoshop or edit video if possible haha
and support most general game... although i hardly play now :D
ragnarok95
Senior Moderator
Senior Moderator
It depend on your budget. AMD ryzen 5000 is quite affordable now.
ronnie_gogs
A older gen AMD 5700G with a B550 would be less than 400 now. DDR4 Add around 60-80 bucks for 16gb kit and another 60-100 for a NVME drive. 550-600 all upgraded.
wongminmin
first what is budget range.....
then u prefer intel or amd....
then u will be re-using ur current gpu or buying new 1?
currently zen 4 is more future proof but the price not very friendly per performance.....
zen 3 is more price friendly.
i recommend asus mobo , 5 years still working..... my msi/giga mobo die after 3 years.
harky
mid range budget? not too old or not too latest model la.. Latest mb of cos ex..
i dont know abit the diff between intel or amd la..
lol i think mb is hang suay ba.. my MSI i use 8-9yr liao.. only now got issue.
i will use back the current gpu till spoilt thn change.
wongminmin
AMD Ryzen 7 5700X 8-core, 16-Thread​
$255​
AMD Ryzen 7 5800X 8-core, 16-Thread​
$295​
with B550 mobo$450~$550
Crucial P3 1TB PCIe 3.0 3D NAND NVMe M.2 SSD​
$65
CORSAIR Vengeance LPX 32GB (2 x 16GB) DDR4$120
Cpu cooler$30~$50
TECWARE/Corsair 4000D/Lian Li with casing fans$40~$120
GPU 1070 $0
FSP 1000 watts $0
u can re-use your hdd/ssd as secondary drive.... but for system drive, i suggest m2....since so cheap now.
32gb ram is more than enough for photoshop or any gaming.
Total: less than $850
If zen 4 build, add another $200~$400
@BlackWing1977 need help on zen4 build.
kaixax555
Do you have a general price target, say 1500-2000?
Phen8210
For general usage just get Ryzen 5000, it has very good value and is also matured platform.
Ryzen 7000 is for people that want to get the most out of their 4000/7000 series GPUs.
deepblue_82
$255​
$295​
$65
Cpu cooler$30~$50
GPU 1070$0
FSP 1000 watts $0
not too bad... where did u get this prices? which shop?
wongminmin
AMD Ryzen™ 5 7600 6-Core, 12-Thread​
$279
MSI PRO B650M-A​
$264
G.Skill Flare X5 AMD EXPO 6000MHz CL36 (2x16gb)$216
$65
guess the blackwing busy......he did a lot of research on 7000 series tho
i didn't do much research on 7000 series... this will be the base build, less than $950
the good thing about 7000 series is come with integrated graphics... so if ur gpu spoil, can run without graphic card. Good for troubleshooting. then future proof... at least for another 3~5 years.
Good enough for photoshop but not sure able to carry your video editing.
For reference only, u may seek others for more professional advice. ;)
then ur 1000 watts psu...i really dunnoe how to utilize..... cause i only see those power hunger gpu build.
kaixax555
$279
MSI PRO B650M-A​
$264
$65
Got any clue what die is on the Gskill kit?
Cause I was thinking Kingston might be better since it is likely to be Hynix A die
wongminmin
my worry for him is the warranty part.... :censored:
amazon kingston warranty able to claim in sg?
kaixax555
No idea, mine is local set but local 5600 CL36 EXPO is about 10 dollars more than G-skill you listed
From the XMP kits that I checked through HWInfo (5600 CL-40 32GB and 64GB kit), the more recent production runs are using Hynix A-die
Since it is Hynix A-die, it should be able to work much more easily across most boards on XMP, and probably can do 6000 CL36 by manually setting and upping voltage slightly
harky
$279
MSI PRO B650M-A​
$264
$65
i think for video editing should be fine because my current can do it but slow only haha
so new mb should be more faster
harky
$255​
$295​
$65
Cpu cooler$30~$50
GPU 1070$0
FSP 1000 watts $0
the m2.. Usually ppl get the MB with two m2 or one?
