need help to build new pc
harky
end up i bought
AMD Ryzen 5 7600 (msi b650 pro)
do anyone had recommand for CPU cooler and NVMe M.2 SSD?
this 2 i can buy online :D
wongminmin
Can't advise. i don't use the main stream... i use ah tiong unknown brand.... better and cheaper.
id cooling and deepcool are china brands. deepcool is good but getting more expensive.
then more builders are using id cooling, guess cheap and good?
When choosing cpu cooler, u look at 4 things
-noise level
-size, able to fit or not blocking.
-come with am5 bracket
- efficiency
just for reference ba.
Noctua NH-U12A chromax.black 60.09 CFM CPU Cooler Noctua NH-U12A chromax.black 60.09 CFM
Thermalright Peerless Assassin 66.17 CFM CPU Cooler​
Deepcool AG400 75.89 CFM CPU Cooler​
ID-COOLING SE-214-XT​
ID COOLING SE 226 XT
Deepcool AK620 ZERO DARK 68.99 CFM CPU Cooler​
KleoZy
ragnarok95
Senior Moderator
Senior Moderator
hmm.. I been using this for friend's build.. use to be 50 plus now 62 but still consider cheap. https://www.amazon.sg/Thermalright-Peerless-Assassin-Aluminium-Technology/dp/B09SD44SL1/ref=sr_1_2?keywords=thermalright+peerless+assassin+120+se&qid=1680920068&sprefix=120+SE,aps,278&sr=8-2
but do note your ram clearance and your rear I/O if your rams block the fan where you have to move to the back of this aircooler.
TBH, at this pricing it's still a very good buy. Still one of the top dual tower heatsink. TS should really consider this.
harky
thermalright peerless assassin 120 (non se if can fit), scythe fuma 2 rev b, deepcool ak620 in that order.
end up i bought this thermalright peerless assassin 120
temp is 51 degree... isit normal?
