Need Help to get my build.
freezeblade
hey guys. so this is my first build so i don't have any experience in building. all i gather is that it is probably easier to get the entire build done and tradeopac and ask for discount. now to the build. what i will mainly be using it for will be gaming. the thing is i need to be able run a video recording program and video processing program simultaneously. so the build needs to be powerful enough to run everything without gimping my gaming experience. budget is about 1.2k including monitor. not including keyboard. can get a slightly smaller hdd since i have multiple ext hdd that i can use. thanks for helping
Yureak
your budget is very tight if you want a machine like that. you should look upwards of 2k for a probably competent one
Jian19
i5-4440 + Asrock h81m hds ~ $300
Crucial 8gb ddr3 ~ $90
Wd blue 1tb ~ $74
Leadtk gtx760 OC ~ $345
Samsung oem drive ~ $21
Fsp aurum s 500w ~ $89
Corsair Carbide Spec-02 ~ $84
Dell s2340l ~ $220
$1223 buy and DIY @ tradepac ask for discount. Can bring o gs shop ask him help u assemble @ a fee if u Duno how to DIY .
Nvidia shadow play is good for recording ....
ryuxdragonx
I'm selling an BNIB ASUS OEM bluray reader and dvdwriter combo @ $55 if you want bluray compatibility.
freezeblade
thanks for the build. but i found that i have a spare monitor at home so i won't be needing one. also is it possible to have a build with a i7 core and maybe 16gb ram? budget is still 1.2k for everything.
freezeblade
did a little research on builds and i got myself a new build. OPINIONS?
MSI Z87 G45 Gaming +i5-4670k~$499
Leadtek gtx760 OC~$345
Avexir Blitz Dragon 1600mhz 2x4gb RED LED~$129 (cybermind)
or
Crucial DDR3 8GB~$90
or
Kingston PC3-1600 DDR3 HyperX 2x4gb
Seagate 2TB 7200rpm~$108
Samsung OEM Drive~$21
Corsair Carbide Spec-02~$84
Seasonic G650 650w 80+ Gold Semi Modular PSU~$135
Random Wireless Card
APPROX~$1321 not including os, wireless and sad
would it be okay in my case to go for the fsp aurum s 500w for my psi
royfrosty
Your $1321 no GPU?
Anyway if you cater more for video recording and processing.
MSI B85M G43 + i7-4770 ~ $475
Crucial 8gb 1600mhz x2 ~ $178
WD Blue 1tb ~ $75
Crucial m500 120gb ~ $128
Powercolor r9 270 2gb ~ $260
Seasonic G550 550w 80+ Gold Semi Modular PSU ~ $105
Corsair Carbide Spec 02 ~ $84
Samsung ODD ~ $21
TPLink N150 USB Wireless Adapter ~ $20
Total ~ $1346. Buy at tradepac. DIY
freezeblade
Your $1321 no GPU?
WD Blue 1tb ~ $75
Samsung ODD ~ $21
is the new motherboard(MSI B85M G43 + i7-4770) better than the one i am considering in terms of gaming? sorry but first time getting diy pc what is a gpu.isnt the leadtek gtx760 OC my gpu?
hengheng220
If you are gaming on a single gpu then no difference but on dual gpu will be different thing as b85 offers x16 x4 configuration while z87 offers x16 x16, however since you are only going single gpu, b85 will be enough. Z87 also offer Cpu overclocking and raid functions which are not present in b85
freezeblade
not too sure about this but I'm gonna stick with one gnu probably since i don't exactly play crazy beautiful games. however i am probably going to try over clocking so would that make my z87 the better choice
shadow84
If you gonna OC your cpu, you are gonna need a good cpu cooler. H80i, h100i, thermaltake 3.0 Pro/Extreme, Noctua D14/D15 at least.
hengheng220
Tbh that's your only choice and b85 killer by asrock. Only z87 can overclock Cpu and b85 killer is the only other exception too. But in the end is up to you whether you want z87 or b85, it's your money ma . Btw if you want to overclock, do rmb to get a k cpu
freezeblade
mainly dota2 but planning to get into more fps since this would be the first time in a long time going back to windows. maybe will get bf4 but definitely the system wouldn't need to be able to run like crzy graphics like crysis.
hengheng220
Ts if I'm not wrong you are just trying out diy that's why wanna step abit into everything right? Hahaha if you got the budget go ahead ba bros here will slowly guide you
freezeblade
you would be absolutely right. first build and have no prior knowledge. Budget is have la. is just depend on how long i have to save before purchasing. cause currently in ns so saving up my allowance for this.
freezeblade
talking about over clocking. i have never tried it out but how much exactly does it boost the system and when would people over clock for? not to show off the numbers but actual practical uses.
Maeda_Toshiie
Haswell overclocking is slightly more involved compared to the Sandy/Ivy OCing with the multiplier and CPU voltage.
On top of that, significant OCing with Haswell either involves delidding or a golden chip (or is it golden thermal paste?) from the silicon lottery.
Overclocking simply results in the CPU running faster, beyond the official stated specs from Intel. YMMV.
hengheng220
Like what the guy below says, haswell will be better than the older gen and also much more heat will be generated, however do note that ocing does not improve gaming performance greatly since more of the work is done by the gpu, so maybe a few frames increase. Do also note the amount of frames your screen can handle, if not too much frames will cause screen tearing
royfrosty
If you are looking in an extra boost in FPS then you will be disappointed. You wont yield much FPS by overclocking your CPU. Is more on how much horsepower can your GPU get you to.
TBH, if dota 2 is a main game that you play, just by adding a GPU into the rig for just dota 2 is gonna be a bit overkill. Dota 2 was never a demanding game to begin with. Its not like at 60fps or more will give you crystal clear heroes or, eye popping defense tower etc.
If you are set to play other high end games like BF4/Titanfall/COD/Hitman/Crysis 3 etc. Then you will need more money on the GPU. CPU is secondary nowadays.
-----> my rig
Even with OC at 4.6ghz, im not getting more fps that i want. Probably just a mere extra 5fps?
