Need help with a Gaming Desktop
Itami_to_Jigoku
Best is Wall Socket, if use extension might have interference so signal not as good. Can buy those that have slot to plug extension in one.
Basically u have a few options:
1) Mobo with built in WIFI (Mostly iTX form factor)
2) PCIe Wifi Card
3) USB Wifi Adapter
Id suggest trying 1 of these 3 options first, then if signal is not good enough, try using those Homeplug/Powerline Adapter/Wifi Extender/Wifi Repeater etc.
Personally, I'd go for a PCIe wifi card if you cant get a wired connection
Sent from Xiaomi MI A1 using GAGT
The wifi card is on top of the mobo right? Or is the wifi card suppose to come with the mobo
Elysium87
wifi card is separately from MOBO.
if u getting a MOBO which comes with wifi itself already, no need get wifi card/wifi adapter.
go get the Homeplug/Powerline Adapter/Wifi Extender/Wifi Repeater etc. to boost the wifi
