xKazeolus
- Jun 24, 2008
CPU & Mobo: i5-3450 & Asrock B75M-DGS @ $300
Ram: Kingston 1600mhz value ram 8GB @ ~$72
8GB is more than enough for gaming.
ODD: HP DVD RW @ $25
HDD: Hitachi Deskstar 2TB @ ~$116
SSD: Plextor M5P 128GB @ ~$150
Install your OS and important programs in SSD for fast boot up and file access time.
GPU: Powercolor 7970 V3 @ $496*
Able to handle most games at high settings smoothly. Come with free game voucher as well.
http://forums.hardwarezone.com.sg/h...oaded-details-asus-power-color-4117500-9.html
Case: Asgard Midgard II @ $87
CM HAF X 942 costs around $259 in Singapore. IMO, you should spend more on your important hardware such as gpu if you are getting a gaming rig.
PSU: FSP Platinum 550W @ $125*
Reliable PSU manufacturer. This PSU has the highest efficiency and comes with 7 years warranty.
OS: Windows 7 Home 64bit OEM @ $110
Total: $1481
Buy and build at Tradepac. Those with * are bundle prices.
Some things to take note when dealing with Tradepac:
- Be firm with your decision when buying from Tradepac. Don't be swayed by their sales assistant to upgrade and buy more expensive components which you don't require.
- Check all the components you plan to purchase are correct before you make payment.
- Stay at the shop and supervise them as they assemble your rig and make sure they return all spare chassis parts. You might want to take note that Tradepac cable management skills may not be up to your satisfactory level.
nipp0n bro, do you happen to know how much is hitachi deskstar 3TB?
