Nice temps leh, got a photo of ur rig setup?Idling/Web Browsing:
Immediately After Gaming:
The configuration of the radiator fans as intake is just plain wrong, period. The radiator is supposed to be warm/hot, as that is where the heat from your CPU is being transferred to by the coolant. You should be expelling the air passing through the radiator outwards, not inwards. You are not only recirculating the hot air in your case, you are now even adding more hot air into it. Whether your HDD overheats or not, this setup is just wrong.
Your front intake fan is useless, change it to 2x 1850rpm Gentle Typhoon ones and post back the temperature.
Another alternative w/o changing casing is to install HDD cooler on the PCB side to cool them.
Your Toshiba HDD temperature is about same as mine in DS418:
but I though that someone did mentioned b4 that Hitachi drive can be quite hot. (or maybe Toshiba?)
but could the HDD be affected by the air circulation in your case? since u have 3x 3.5 in it. (space enclosed might be quite tight?) btw is your X and Y drive also together with this hot HDD?
But HDD by default is passive cool ma. Many cases designed without having much active cooling for HDD also. Reach so high temp a bit weird leh for this case. Maybe as what ZrE0_Cha0s said, Hitachi run hotter than others?
Also, what's the temps for the others HDD? All equally high or just the HGST one?
Sent from Finally Unbanned using GAGT
Haha.. if got lower means I keep casing open forever ar?
Going forward, you should be looking for a replacement casing.
You try this yet?
You can always rig an 80mm fan or so inside the case to blow at the fans if you've space
Sent from OnePlus ONEPLUS A3000 using GAGT
Oh ya.. they include that tiny fan...I can try to put my Cryorig A40 Ult small Cpu top fan there to see if it helps.
