Need help with my PC
Aneosx
Hi i had a problem with my PC. I cannot power on at my house but when i send to servicing centre, it can be powered on at their centre. I already went down twice and i still cant power on.
I am running out of ideas on why it can be powered on at service centre but when i bring back i cannout turn it on. Would greatly appreciate any help or ideas on what to do.
thank you
tigerwoods
thank you
Try other electricity oulets in your house.
Someone has posted this problem before.
Aneosx
I tried living room and another bedroom and it still cannot power on. Am beginnjng to wonder is it my house voltage issue
Alphas
Then it’s nothing to do with the capacitors, do you what is the function of capacitors?
Aneosx
i think i drained out the power electricity inside the capacitor and than my pc can managed to be powered on
tsteo77
nope i think its the capacitor problem. i plug off my power plug and switch off the pc switch. i than press power and for few seconds and try plugging in and it work
The power stored inside the psu capacitor will return to the power line after switch off. If it does not, i think your return line is faulty. You should check your power cable and/or ask an electrician to check home's power lines.
