Need Help with Work Rig
i.curtis
Hello,
Im intending to make a new Rig for work and really need your expert help. I use it mostly for surfing the net, watch videos, emails and excels sheets and very small games like online poker etc. I want the computer to be fast speed, so not much lag when using. I store quite abit of photos from my trips as well
Please do recommend me a rig to get, budget maybe 800? but flexiable. No need monitor etc, just the rig
daniel798
Easy as you do not need a graphics card
Asrock H81M-DGS + i3-4130 $221
Kingston 8GB $95
Xigmatek Asgard XP + CM 500W Thunder $88
Win 7 64bit $115
Total: $519
For storage:
Seagate 3TB $143
Crucial M500 120GB $114
Total: $776
You could spend the remainder on a dvd drive if you need one
i.curtis
Thanks for your suggestions,
Is it better if I add in a graphics card? Or there really isn't a need.
And with this sset up its good enough to be lag free?
QUOTE=daniel798;85628590]Easy as you do not need a graphics card
Kingston 8GB $95
Win 7 64bit $115
Total: $519
For storage:
Seagate 3TB $143
Total: $776
You could spend the remainder on a dvd drive if you need one[/QUOTE]
MoneyFace =p
And with this set up its good enough to be lag free?
What's the most demanding you think you will play?
royfrosty
TBH, getting an i3 is also not needed.
My recommendations.
$800
Asrock H81M DGS + Intel Pentium G3220 ~ $148
Crucial 8gb 1600mhz ~ $89
WD Green 2tb ~ $108 (For your movies and other storage needs)
Crucial m500 120gb ~ $115 (For a fast boot up time, and also for overall smoothness of the PC and overall OS responsiveness)
Coolermaster Elite 311 + FSP Hexa 500w 80+ ~ $105
Samsung ODD ~ $21
Windows 7 Home Premium 64bit OEM ~ $110
Total ~ $696. Buy at tradepac. Diy
i.curtis
Thank you for your reccomand action
If I got the i3 inside this set up, will it make much of a difference? I would want something to last and not slow down after a while
Thank you for all your advices
My recommendations.
$800
Samsung ODD ~ $21
royfrosty
Most to most is just facebook games or online poker.
This kind of games is not demanding. THey dont need a gpu. Most important is your internet connections/speeds.
There isnt any thing that you are running that requires an i3. Not justifyable for the need of it.
SSD is the one that improves the overall speed of your PC.
Not unless you thinking to go for real gaming stuffs. Then you would require an i5.
i.curtis
Ah ic,if I need to from time to time use photoshop/illustrator would that then require a graphic card?
So if I want to even further quicken my comp speed I should get a faster SSD? Bigger then 120 GB?
Sorry for all the noob questions
royfrosty
This would be a bit different.
Do you really often use photoshop? What do you do with it? Cause this will affect the overall cost of the rig. And probably you might wanna get a mid range gpu. So better think carefully. And photoshop needs rams.
No, SSD bigger storage dont really mean faster speed. Is the type of SSDs and the particular model the brand has.
i.curtis
Thank you for your patience,
I might be looking at 2 rigs I realize, 1St for my dad, like what I have been saying, emails, movies, light gaming like online poker and facebook games
This would be your recommendation right? If I want to upgrade abit more, say if can make the speed even faster to minimise lag?
Samsung ODD ~ $21
And let's say for the second rig, again mostly for work, emails and alot of excel files will be multi tasking alot with a number of things opened at once, very light photoshop to do simple graphics like posters. What would you reccomand. You have any recommendations for monitors as well? Want something big and very clear.
Thank you so much for your time and expertise again appreciate it alot
QUOTE=royfrosty;85664001]This would be a bit different.
No, SSD bigger storage dont really mean faster speed. Is the type of SSDs and the particular model the brand has.[/QUOTE]
Jian19
$800
i5-4440 + Asrock h81m hds ~ $300
Crucial 8gb ddr3 ~ $90
Crucial m500 120gb ssd ~ $115
Wd blue 1tb ~ $74
Samsung oem drive ~ $21
CM 311 + Fsp hexa 500 ~ $105
Win7 64 oem ~ $115
$820 buy and DIY @ tradepac ask for discount. If not sure how to DIY can bring to gs shop ask him help u assemble @ a fee.
Monitor wise Dell u2414h ~ $375
MoneyFace =p
Samsung ODD ~ $21
Thank you so much for your time and expertise again appreciate it alot.
Why don't you just get the more powerful PC and share with your dad since you are looking at just 1 PC initially? Just don't see why you need 2 PCs if you can do it with just 1 and also when both are going to differ by just the processor.
CPU+MB: Intel Core i5-4440 + ASRock H81M-HDS @ $298
Intel HD Graphics 4600 should be adequate for your Photoshop needs. Use ASRock XFast RAM to create a RAM disk for Photoshop acceleration if required.
RAM: Crucial DDR3-1600 CL11 8GB @ $92
SSD: Plextor M6S 128GB @ $119
Newer, faster, slightly bigger, 5 years warranty.
HDD: Western Digital Green 3TB @ $144
Best value, low power, 3 years warranty.
ODD: Samsung 24X CD/DVD Writer [OEM] @ $21
PSU: FSP Hexa 500W [80 Plus] @ $58
CASE: Xigmatek Recon @ $45
OS: Microsoft Windows 7 Home Premium 64-bit [OEM] @ $115
Total: $892
Optional:
DSP: QNIX Evolution II QX2710 27" LED [PLS] @ $274 (qoo10)
Buy others from Tradepac, #05-18.
