Need parts recommendation for Threadripper 2 system...
djr81
Its been awhile i build a AMD system.. i think the last unit i build is a A64 3000...:s22:
anyway below is the part i plan to get.
Mobo - Asus X399-E
CPU - AMD Threadripper 2950X
CPU Cooler - Noctua NH-U14S TR4
Ram - Any recommendation? (Need 32gb)
SSD - Samsung 970PRO NVME 1TB
HDD - WD Black 4 TB
GFX - Quadro P4000
Monitor - Dell U2417H x 02
PSU - Superflower Leadex II Gold 90+ Full Modular 750W (Black)/ Seasonic Prime Titanium 650TD/12yrs
Casing - Fractal Design Define R6 TG ATX Casing
TIA
:s22:
singupingu
Why do you need such an OP system?
Sent from OnePlus ONEPLUS A3003 using GAGT
djr81
Wah, for what kind of usage?
Wow quadro and threadripper. For professional Cad design?
Yeh.. For pro cad designer, vray, 3ds max.
last few mth purchased 2 set i7-8700k system liao..
just want to trytry AMD Threadripper 2..
any recommendation for the parts?
:s22:
-Grift-
Unless you wanna go with semi AIO cooler kits from EKWB the H150i really looks like the way to go for 360mm rad.
ECC ram or just normal kits
enenyi
Mobo - Asus X399-E
CPU Cooler - Any recommendation? ( thinking to get this CORSAIR Hydro Series H150i PRO)
HDD - WD Black 4 TB
GFX - Quadro P1700
PSU - Any Recommendation
TIA
:s22:
For GPU, there is no Quadro P1700.
Either u meant Quadro FX 1700, or Quadro P1000.
In this case, a Quadro P1000 would be enough.
Kusanagi
Since it’s work station i think you can get value rams
not sure if AIO is a good idea for this as well
PSU can get seasonic prime with plat efficiency and above
-Grift-
If even intends to overclock or even allow the chip to auto OC he is gonna need it IMO especially a 360mm+ cooler. My Cryorig R1 can hardly even handle my 2700X
djr81
ok.. any cooler to recommend ? like which model?
:s22:
djr81
will skip AIO since it still not so stable after looking some photos of leaking issues...:s22:
Any recommendation for ram?
some say must get C14 some say must get 4 x 8g :s22:
So what ram i should i get??
tks
Kusanagi
tks
ya air cooling is more fuss free, it’s a work station after all right? :o
clock speed is up to you, but config 4x8 is a must, if you are getting the noctua air cooler, do take note of the ram clearance, so nothing too fanciful as well
djr81
any ram recommendation?
i read some forum until :s12::s22:
so get 4 x 8gb DDR4 but what spec i should buy 3200 c15? or?
:s22:
Kusanagi
:s22:
just go research on quad channel ecc rams
personally i don’t go for high clock freq rams, especially on the TR, you will probably not be able to run at rated clock speed
aCuria
Can spoonfeed boh...
:s22:
Corsair has higher frequency ecc, and threadripper scales with frequency, so this is the best ram you can get to my knowledge:
CT4K16G4WFD8266 (16gb * 4 kit), DDR4-2666
Its not cheap though, ram prices are very high and have been ever since flooding destroyed the ram factories in thailand... high demand + constrained supply
once upon a time 4gb ddr3 was $23 at sls =x
aCuria
GPU can get 2080TI... depends what you want it for right, but that card has lots of tensor cores, good for ai. Its a cut-price titan
PSU wise the best one would be the seasonic titanium series, maybe 850w will out-last most of the stuff in your PC given the super long warranty.
note that the threadripper boards need 3/4 power cables going to your mobo... make sure the PSU is strong enough =/
for gaming the cheaper intel 6 core or even a ryzen CPU would be better. Threadripper costs allot more (4x ecc ram is expensive, needs a better PSU, runs hot, cpu and mobo more expensive. You gotta look at your use case really.)
If your usage is not so ram intensive you can get away with one stick of ecc. not optimal though.
