Need serious help (machine off by itself)
ykrap1
Try isolate the problem one by one starting with hard disk power supply and finally graphics card
twlee88
It has x2 4pin. I just put that in..24 pin..ram..and connect front panel..now it doesnt even on when I press on.did I miss anything?
twlee88
Guys..I tried..and it still the same..the cpu fan is not running at all..just the power supply fan run then off..
twlee88
Guys..just try out old 500w power supply..and the thing worked! so I take it the new super flower psu is the problem? or my connection? and 500 able to support gtx 970?
Alternative X
A good quality 500W PSU is more than enough to power a GTX 970. Maybe your Superflower PSU is DOA (Dead on Arrival). Can you start up the system with your old 500W PSU? If you can use the system, go to Tech-Dynamic (The distro of Superflower PSUs) with your Superflower PSU and your reciept from Lazada and ask for a 1 to 1 exchange.
twlee88
since I just connect using old 500w with ram , front panel, cpu and mobo..it can get into screen asking for boot. now im trying to connect the rest and see how..do I still need to boot win7?
twlee88
and I dono acer predator g3620 500w is good quality or not to support gtx 970
twlee88
Yayy!!! I can get in window!!! *jumping like *****...now I just need to slot in my gtx 970 and hopefully the psu is able to support it!
twlee88
ok. once I plug in palit gtx970..all is working..but the monitor just on sleep..and in a while the gpu fan stop (light still on)...any idea? 500w not compatible?
twlee88
"Please power down and connect pcie power cable to this graphic card"..anyone?
twlee88
connect the x2 6pin to gpu..able to boot but keyboard and mouse not usable..and the gpu fan stop spinning in around 2 min
Alternative X
The part where the fans stop spinning, that is actually part of Palit's GPU cooler design where the fans will stop spinning and will only start spinning at a certain temperature for maximum silence. (MSI and Asus's GTX 970s have this too.)
For your issue with the KB & M, got any ancient KB with a PS2 connector, like this:
I suspect that your motherboard Bios may have disabled any USB devices/ports at startup. You need to access the Bios with the PS2 KB to change the settings. If you do not have one, try clearing CMOs to reset any motherboard settings.
twlee88
now I enable the mouse and keyboard..final 1 will be internet connection..I plug in ethernet but no connection..any idea?
twlee88
All done!! able to play game in ultra setting! much thing to learn and change in this new mobo. the fan seems to make loud noise compare to my old MoBo.
But all fine now. see how long it will last!
Thank you all guys from Hardwarezoner~~~
1st overhauling success!! (some item broken or bend but...gaming now!
zenniz
Most probably your cpu and gpu's cooling fan is working hard to allow the processor to produce smooth frame rate at ultra setting while keeping everything cool.
bikoyski
this thread really put a smile on my face.
lots of help from a lot of people and not a single negative post.
twlee88
u r right! you guys are totally awesome!
thanks a million! i can now play high setting game =))))) :s12::s12:
