Need serious help (machine off by itself)
twlee88
I just change my psu, mobo and gpu to my existing Acer Predator G3620.
PSU: Superflower 600
MoBo: Asrock B75m
GPU: Palit GTX970
Al done and when I on my computer..the fan started moving then the whole thing off.
Need help here T.T
Alternative X
1) Reseat all connections in the rig.
2) Check under the motherboard, make sure there is no metal parts (ie screws, wires) under the motherboard.
3) Reseat CPU cooler.
twlee88
Im gonna try that tonight...the moment u finish assembling all the computer parts and u press on...few sec and it off...its depressing :(:(:(
twlee88
I will try again tonite. if things still the same, will bring to shop for them to assemble.
Any recommendation and average price for diagnosis and assembling?
or know anyone that willing to come over to do the assembling and diagnosis?
Alternative X
Can just bring your rig over to PC Care & Solutions, #02-32, Sim Lim Square, and have Nigel take a look at your rig.
ykrap1
try invest in a good CPU cooler, something like this
twlee88
Is there any way to book his time? im sure alot of ppl are looking for him based on some post in this forums
Jian19
Just pm him and arrange a time slot
Do check if u connect all the 8pin connector and fan connector, ur gfx need to connect as well
twlee88
How do i PM him?
I did connect all in. there is power..but it just within 1 sec and it off agn..something somewhere is wrong or spoilt..thats the worse....
sglords
U Gt put thermal paste on Cpu?
Test everything outside of the case
Without anythin except psu ram mobo and cpu
royfrosty
Prime suspect. Most likely somewhere shorted.
1. Check all psu connections are right - 24pin to motherboard. 4pin that is blue connectors labeled as cpu is to top left corner of the motherboard. Please check the orientation of the 4pin. Ensure that the 6pin that is red color connector that is labeled as PCI express connected to you graphics card.
3. Resit your processor. Before you resit, check the orientation of the chip. Make sure golden arrow is on the bottom left of your socket.
4. Ensure that your HDD/SSD has fully sitted in sata powered.
5. Ensure that your gpu is fully sitted into the pcie slot.
6. Ensure all rams are fully sitted into the ram slots.
7. Check your casing, does it have any standoffs. If there is no standoffs most probably you will get shorted somewhere.
xkiller213
2. Make sure there are no unused power connectors (PCIe/SATA/Molex/etc) that touch your MB...
kena once before :)
jtjt00
So you install a standard motherboard off the shelve onto an OEM casing?
twlee88
just a question..I put my mobo at the box..connect 24 pin power and 4pin x2 with ram and power button..can I run with it?
