New DIY PC Advice!
ZrE0_Cha0s
well all we can say is that u have to try to test it to find out. (its actually similar to SLS shop have kept some old stocks and nv sell it at all and out of the sudden put it on sales)
Providence
I see. Thanks for the heads-up.
Providence
This is my first PC configuration that is compiled from the PC Themes' price list.
Processor/Mainboard - Intel i5-7500 3.4GHz & ASRock H110M-HDV ($388)
Ram - Kingston 2133MHz CL15 8GB x 2 ($170)
Graphics - ZOTAC GTX 1050 Ti 4GB DDR5 ($225)
SSD - Western Digital Blue 250GB 2.5" SSD ($145)
HDD - Toshiba 1TB 7200RPM SATA ($63)
PSU - OCZ ModXtream-Pro 700W ($0) ~ Still mint-in-box after RMA many years back
Casing - Fractal Design Define C ($149)
Media - Asus 24x DVD-RW SATA ($25)
Monitor - LG 22MP48 21.5" ($179)
OS - Windows 10 Home Edition ($158)
Total: $1502
Providence
This is another PC configuration based on the pricelist from Tradepac. A few of the items are not priced so I based them on PC Themes' instead.
Processor/Mainboard - Intel i5-7500 3.4GHz & ASRock H110M-HDV ($377)
Ram - Kingston 2133MHz CL15 8GB x 2 ($168)
Graphics - ZOTAC GTX 1050 Ti 4GB DDR5 ($182)
SSD - Western Digital Blue 240GB 2.5" SSD ($137)
HDD - Toshiba 1TB 7200RPM SATA ($59)
Casing - Fractal Design Define C ($149) ~ PC Themes' price
Media - Samsung 24x DVD-RW SATA ($21)
Monitor - Samsung S22F350FHNE 21.5" ($0)
OS - Windows 10 Home Edition ($158) ~ PC Themes' price
Total: $1251
The monitor price is also unknown.
Providence
So what do I need to 'tweak' on the above configurations? :s13:
MSI graphics cards are too expensive. Bo pianz... Have to find ZOTAC instead... :D
ZrE0_Cha0s
can consider going for value ram if u are not going to OC ur ram (which also cant OC with that board :s8:)
if dun need dvd can remove.
OS can consider buying from other place (online purchase)
for gpu can consider going for GTX 1060 3GB ( more performance boost)
Providence
The RAMs that I stated are performance type? Argh... I copied it from the PC Themes pricelist.
So you can install the OS via a USB drive? :s11:
singupingu
Yes you can.
https://www.microsoft.com/en-au/software-download/windows10ISO
Just need a 8gb thumb drive.
Then you can omit an internal DVD drive and get an external one. You will hardly use the drive tbh. So if you can borrow, you borrow.
SSD get Ocz TL100 @ $120. Same stuff as WD Blue ssd.
You can squeeze Tradepac price to be honest. Usually another 5-10 bucks off pc theme pricing per item if you manage to bargain.
Sent from Overpowered Phone Mark III using GAGT
Providence
Yes you can.
I see. Thanks for the heads-up!
By the way, which ASRock motherboard is affordable and still can be accepted as mid-range motherboard?
I think my choice is way too outdated.
singupingu
It doesn't matter that much to be honest.
If you can afford, B250M Pro 4 is the next step of upgrade. Buy 2400mhz ram to match the motherboard max supported memory frequency as well.
Providence
After much research and consideration, I have modified my PC configuration list slightly.
I hope it is enough to support Battlefield 1, Mass Effect: Andromeda and Titanfall 2.
Processor/Motherboard: Intel i5-7500 3.4GHz & ASRock B250M Performance (Fatal1ty) -- $413
RAM: Kingston 2133 DDR4 (8GB x 2) -- $164
Graphics: MSI GTX 1050 Gaming X Ti 4GB -- $265
SSD: Kingston 240GB UV400 -- $120
HDD: Toshiba 1TB 7200RPM SATA -- $59
PSU: OCZ ModXtream-Pro 700W -- $0 (Mint-in-box - RMA item
Casing: Fractal Design Define C -- $149
Monitor Samsung 21.5" S22F350FHNE -- $0 (Unknown price)
Total: $1170
I will use my wife's portable media drive to install Windows 7 Home Premium and then upgrade it to Windows 10 Home via the USB drive. Is that possible?
The monitor, keyboard and mouse. I still need to buy a monitor though. Haiz... The keyboard and mouse -- I have spares at home. The mouse is still a Razer one -- Mint-in-box (I forgot why I bought it last time and never use :s13:
singupingu
Nah. Just use an existing laptop or pc, download the Windows 10 and follow the steps on screen to make a USB-ESD to install Windows 10 directly from the thumb drive into your new com. Then go carousell or anywhere else, buy a Windows 10 key and activate it.
Monitor try to find Dell S2316H. Pretty good monitor, 1080p 60hz IPS display with built in speakers. Carousell have. About $160 range.
troublesome58
??? You are getting this PC in Sept. Why are you building the component list now?
Don't waste your time.
Providence
I just want to know the estimated cost of the setup. I think the cost will not fluctuate so much within a few months.
Furthermore, I also need some insights on the current budget-like gaming setup. Based on my current rig, my setup was way too outdated in a technological sense. :s13:
The graphics card and processor/motherboard trend have evolved a lot since my rig setup 5 years ago.
Providence
Is it trustworthy? I read on some forums that these sellers will resell the serial keys over and over again to different people. Till the point that the serial keys become invalid. :(:eek:
