New graphics card problem
Alesso94
PC noob here, I ordered a Palit GTX 750 TI from Convergent thru lazada to upgrade my prebuilt Acer Predator G3620.
I disabled secure boot and performed a clean uninstall of the old drivers and popped in the new card. I booted up the PC and was greeted with this glitched out Windows 8 home screen: imgur.com/qFG67CJ
Is there a step that I've missed or is the card faulty or not compatible with the motherboard/outdated bios? Thanks in advance.
wad3v3r
try installing the nvidia drivers in safe mode ?
emb the picture for you
Koenig168
The mobo is known to have compatibility issues with GPUs. Some have solved the problem by disabling SecureBoot. Others required a MB replacement.
Koenig168
hlots123
looks like vram problem tho, show pic to convergent see if this means rma
btw do u have any oc software (eg afterburner) on startup? if yes can u uninstall or disable it from startup 1st
Convergent Systems SG
Featured Distributor for Hardware Clinic
Bro,
It might be a bad GPU.
Please bring it down to our Service Centre for through testing.
*** Ian ***
