As my room gets dusty often need a case with easy to remove dust mesh for cleaning. Any recommendations to go along with the build I am planning to buy and any improvement I can change in the build?
Planning to get from Tradepac from SLS
Current pricing now is 1990
PCPartPicker Part List: https://sg.pcpartpicker.com/list/NRgMdm
CPU: AMD Ryzen 5 3600 3.6 GHz 6-Core Processor
CPU Cooler: Corsair H100i RGB PLATINUM 75 CFM Liquid CPU Cooler
Motherboard: Asus TUF GAMING X570-PLUS (WI-FI) ATX AM4 Motherboard
Memory: Corsair Vengeance LPX 16 GB (2 x 8 GB) DDR4-3200 Memory
Storage: Samsung 860 Evo 500 GB M.2-2280 Solid State Drive (recycle from old com)
Storage: Seagate 2 TB 2.5" 7200RPM Internal Hard Drive (recycle from old com)
Video Card: MSI GeForce RTX 2070 SUPER 8 GB GAMING X TRIO Video Card
Power Supply: Super Flower Leadex III Gold 650 W 80+ Gold Certified Fully-Modular ATX Power Supply
Optical Drive: Asus DRW-24D5MT DVD/CD Writer (recycle from old com)
Operating System: Microsoft Windows 10 Home OEM 64-bit (recycle from old com)
Personally, ever since about 10yrs ago, I bought a USB optical writer for standby. Use it less than 10 times since.
ya I do wan my wifi due to the inbuild Bluetooth for my ps4 controller and my LAN port is in a very bad location due to bad construction (nid to play my monster hunter ) this is my upgrade in 5yrs.From my option, he wanted to have wifi6 card ba, only x570 have compatibility on wifi6, therefore he chose tuf gaming, i would suggest u to check on amazon and newegg for the price and compared with sls vendors, sometimes online is much cheaper but provided u are not rushing to new build
I hav no issues with corsair kits b4 my current ones, seems ok leh, never heard of major issues unless u are going to extreme oc with corsair kits
its an old 1 not gonna let working parts go to waste hahaOverlooked the optical drive,.... WHY?
In this day and age there is no need for this anymore. Windows should be installed via a USB stick and its a lot easier to download and prepare than you may think. Just need to make sure you have a valid key ready or just install it and activate later.
Just to close this off,.. look at all newer cases - they have done away with the front panel where you install these dinosaur drives.
preferable below 200do you have a budget in mind for your casing?
