noob trying to build pc
lamtheboy
Whew $6xx need time to farm ehh.i cannot wait liao 4yrs since i fried my last desktop
760 is very value for money, hard to beat at that price point. At 1080p it performance very well, just Google for benchmarks. Very playable fps
Ark Law
Why others need firmware updates?
Some of the others require stability/performance/longevity/compatibility firmware updates. Intel and Samsung (in my perception), particularly Intel, do much more extensive in-house validation compared to the competition.
There's a reason why the 520 series was the hot-seller before the Vector/M5Pro/840Pro era, it worked fine out of the box, required no updates and makes it the ideal drive to be used when building systems for non-tech savvy people
numbers
Wondering if 760 is the choice? The review sucks. Motherboard so many wonder what's the different? Ur choice also don't intend to OC right?
yea i dont intend to OC...u recommend i should get the cheaper haswell mobo such as the 4430?
royfrosty
You wanna save a bit ok lah. The performance for gaming wise is negligible. But is $20 away from the 4430 to 4570. So up to you ba.
lamtheboy
Just get 4570 because normally if you upgrade pc for gaming you change gpu, your cpu is like a one time investment :D
squeeish
Are you the type who takes good care of his stuff?
If so, get a good casing if you can, so it can last you years and also have good cooling solutions, which in turn prolongs the life of your components as well.
numbers
coolermaster elite series casing good?
Bieffe
Good enuff to me. Take the 431 plus. Has 1 USB3 and 1 fan. Just add one more fan at the rear for abt $15. Should be good enuff.
Do note this case the PSU is mounted at the top.
numbers
MSI B85M-E33 with i5-4570
Palit GTX760 2GB Jetstream DDR5
G-Skill RipJawX 1600MHz CL9 8GB
WD Caviar Blue 1TB
LG GH24NS50 24x DvD-Writer SATA
DELL 23” U2312HM IPS LED
this setup need 500w or 550w psu ah?
i wont be doing SLI or overclocking in future....
lamtheboy
WD Caviar Blue 1TB
a decent 500 should be enough
Bieffe
WD Caviar Blue 1TB
5ow to me little diff. Get a good PSU. Some brands over rate themselves. Take 550.
shadow84
so.....if i get a good coolermaster 500w the rig will work right?
actually what will the extra 50w do ah??.....
Get from FSP, seasonic, super flower.... Best trusted brands... CM is one of the worst. Seasonic does OEM psu for Corsair.
can consider the thermaltake psu or seasonic m12ii 550w.
That extra 50w is for allowance. How it works is that if your psu is rated at 500w, it actually provides lesser than that to your system, due to heat loss and efficiency.
