Try using other camera app which have macro feature?
Tried an Apps, CameraMX, seem the same. My wife having same phone taking same object, same lighting condition and hers look much better then mine.
Any other Apps can recommend ?
Thanks...
It's easy to reproduce the problem. Just go to a dimly lit place. It doesn't need to be too dim; just enough to warrant night mode. Then try to focus on anything. 90% of the time, the camera can't lock the focus even though you can see that sometimes (for a fraction of a second) the image is quite sharp in the viewfinder when the focus is adjusting. But the focus just keeps changing and finally the red rectangle shows up.
The latest OTA update doesn't solve this problem.
I don't think it's hardware issue. Better not exchange your phone. Your new phone may have other problems (dead pixels, button too hard, screen with slight imperfection, etc.). If you are unlucky, the process could be very frustrating and time consuming.Ya.... You are right. The problem is the same as what you have mention. Will go down to Samsung at jurong point to ask for 1 to 1 exchange.
Hi,
Anyone had the same problem, camera auto focus problem, as I encounter.
Can't take clear and sharp picture when close up on object to take picture.
Anyone can advise?
Thanks in advance.....
Hi,
Anyone can advise?
In this case, you shall ask for 1 to 1 exchange, bring your wife one together and proof to them.Hi All,
Thank you for all kind advise. The plastic sheet is removed. I took my wife same model of phone took the same picture with same setting and hers work fine. should I go to singtel ask for 1 to 1 exchange or Samsung?
