Note 4 Battery Life
x1aojie
I mean, over the course of the day. If I remember correctly, "mediaserver" should only appear if you've been playing music or video. Otherwise it could indicate another unnecessary battery draining service that's been left on for some reason. I used to be pretty OCD about these things when using a Desire S with lousy battery life. :p
The screenshot i taken was right after Factory Reset. It was there all along. Do you have it? Or do you mind showing how's your page looks like ?
RequiemDK
Mine isn't a Note 4, but I can post a pic of my battery usage here tomorrow for reference. I did post one or two screenshots earlier in the thread, but that was for a special experiment to determine the max battery life with a (rooted) Note 3.
iwcmanic
Hi all,
Is there any tips or apps to install to save the batt life?
Sincerely, thanks in advance.
PS> My batt last less than 11 hours as stated in most of the reviews.
robolee
1 hour of spotify music + brave frontier + 4G network + auto brightness at -3
90% to 67%
jianrong
When go to bed. Turn on ultra power. When working turn on power saving. It help. I also have battery app that turn off background apps to gain battery power.
fatangel
Like that very busy.
Become a slave to the phone.
Just use it normally la.
Time to charge jus charge..
jianrong
1 Days 13 hours + Standby.
With 6 hours of SOT. Plus power saving mode on.
Just left 8 %. Now charging the phone.
:s12:
blurtaurus
Hi guys,
I have noticed something weird with my Note 4's battery. Every time after charging, the battery consumption is quite high. It can drop 4% in 40 mins while in sleep mode. I will have to turn off the phone and turn it on again before it becomes better (from 10.30pm to 6.30am drops only 4%). Wifi, data, bluetooth, NFC are all off. Sync is also off. As phone is not rooted, can't tell much from the setting's battery page.
I did a factory reset but the problem persists. Only install a few apps like screen on/off app, google pinyin keyboard after the reset. Its quite ridiculous if I have to turn off and on the phone every time the phone is charged to get reasonable battery consumption.
Anyone facing this issue who can share his/her experience?
Thanks.
renfred89
Hi guys,
Thanks.
Nope I dont face this issue. There are a couple of possibilities here. It could be your firmware issue or could be your applications.
Usually I would clear the cache via the recovery menu first and observe for another few days. If still cannot, I will do a factory reset via the recovery menu.
If still cannot, then bring down to service centre..
einstein21
Hi guys,
Thanks.
Hello, did you manage to solve your issue? I'm also having the same problem. Before going to sleep, my phone is fully charge to 100%. When waking up battery is now at 91%-93%. Wifi off, no background process running. Hope you have solution for this.
blurtaurus
I tried what renfred89 suggested. Cleared cache from recovery 2 days ago. Seems fine until now but still monitoring the situation.
You may want to try and share your results.
einstein21
Thanks! I manage to fix my issue. Last night, from 100% to 99% overnight. Actually, I did a lot of things, I don't know which one is the fix. In Wifi->Advanced Settings i set to Never the Keep Wi-Fi on during sleep and unchecked Always allow scanning. I also installed Greenify app and hibernate suspicious apps that may cause wakelock like Yahoo Mail, Player.fm. This apps have sync functions enabled. Will continue to monitor.
blurtaurus
Glad that things turned out ok for you.
Everything was fine until battery level fell to around 50-48%. Then the battery level started to drop faster and faster without using the phone much. Was at 29% last night at 9.40pm, when I woke up this morning, phone was off. Must have gone totally flat in middle of night. Sigh...
einstein21
Maybe you could provide screenshot of your Power Saving settings and Battery History Details. You just go to Power Saving and click the graph. It could show you what is causing your battery drain. For my case, it is an app that is causing my phone to wakelock. I installed Greenify to hibernate this app and now I don't have the issue anymore.
blurtaurus
Thanks. But tired of trying this and that. Already reset the phone 3 times. Sent to service centre to have it checked out. Hope problem can be resolved.
anirudhks
Some of u may think this is bullshhh but for many that i suggested around did work.. those who see major drain is bcos the fast charging is not functioning for few handsets .. the battery % just jumps and doesnt report correctly while discharging. . If u have extra battery best use the battery charge to charge ur batteries dont charge via phone .. else disable fast charging and charge normally via normal charger.. see the difference your self.. i had this problem few days back now its ok... may be a software bug
Sent from GAGT Android App
blurtaurus
Hi guys,
Looking for some feedback regarding battery consumption. I have been having some battery drain issue since Oct. I got my set but yet to solve it although I have sent in for repair twice. First time changed motherboard and battery while second time they tell me no problem at all with the set, battery and cable.
Overnight, without using the phone in between, my note 4 drains battery of about 10% in 9 hrs with wifi, bluetooth & data turned off, which I think is too high. My colleague's does not drain so much, about 5% only.
Yesterday, I turned switched my network to GSM instead of LTE and got much better battery usage, 3% in 7 hrs.
Correct me if I am wrong but I don't think its normal to drain 10% in 9 hrs with wifi, bluetooth and data turned off. Just wondering what your battery drain over the night is? Especially for bros out there who are on M1 network (as mine is). I suspect my LTE components could be faulty. Want to be sure before I send to service centre for 3rd time.
Appreciate any feedback. Thanks.
jason910
Can I ask how do u access the recovery menu to clear the cache?
