[Official] Dior Homme Thread
charleslin
is this umc 07?
Yup, UMC 07, had that worn out patch on the right knee.
UMC 07 -
UMC 08 -
charleslin
how does the fit go? i only got a pair of mij raw. how does it fit compare to a mij jeans?
Slightly looser than MIJs of the same size, but it won't stretch much unlike Raws, so best to at least size up one.
UMC 07 was 100% cotton if I remember correctly, unlike UMC 08 and 09 which is 98% cotton and 2% elastane, so UMC 08 and 09 was slightly stretchable.
charleslin
There's also 17.5cm UMC 09, but not that common, I know France Dior Homme boutique got the 17.5cm.
death7878
charles, got lobang for MIJ raw indigo? wats the pricing like? haha.. can PM me?
now tinking whether wanna let go my VoTC 04 washed or not arghhh!
charleslin
just to check,for their wash jeans is it advisable to down size?
Depends on how you look at it. Dior size or actual size.
Because normally the jeans are 2 sizes tagged down, so a 30" is 32" when measured.
If MIJ Raw is size X, best to at least size up 1 (X + 1) for washed, sometimes even 2, depending on high tight it is for the MIJ.
Best is to try it though, because sometimes the fitting might vary a bit, normally Japan ones are tighter than Italy made.
But don't size down from actual size, as it won't stretch much.
What size you wearing?
Got pics of your washed? :D
AlanSmith
thanks for the advice
so means if i try the size in boutique and it fits nicely dun downsize anymore?
charleslin
Yup, for washed don't down size anymore if you tried one that fits nicely but not tightly, should feel ccomfortable.
It will stretch a little bit only, all jeans will.
As for raws, it's best to get the size, when worn the first time at the boutique, unable to close the clasp easily or the top button as well, to allow for stretching.
fuallupdown
LOBANG FOR MIJ RAW Indigo SZ 28????
When the F is Dior opening? i need to take off go there shopping
AlanSmith
oh..ok thanks for the advice..
GamerZ
Club21. Thats why there is speculations about the price being... rocket high. Maybe 480+ for raws?
Eh you sure its C21? I never see the word C21 on Dior store front leh.. Unlike Dolce & Gabbana where they put C21 big big on the store front.
EquinOoX
if its C21 its gameover, but the thing is there is Christian Dior Singapore Pte Ltd. I dun think they will let C21 have rights?
