NeonX
Cause e27 bulbs are huge and can't fit my light casing
Never seen people using e27 bulbs for lights in false ceiling leh
I have used US white hue bulbs here, but you need to be very careful with turning them on/off. It is not as sturdy as bulbs of 220/230v. I have blown a few bulbs of the 110v ones.
Just curious, why are you using GU10 and not E27?
waterfoe
Should consider Insteon
Hi,
I have integrated Insteon line of product in my new home.
My setup are as follow:
1. 4x 8 key switches
2. 12 micro module
3. Insteon hub 2
4. Amazon echo
5. Amazon echo dot
6. Logitech harmony elite
7. 6x Philips hue E27 bulb
8. 11m Philips hue strip plus
9. August lock
10. Haiku fan
Totally in love with the above setup....
Yureak
Hi,
2. 12 micro module
3. Insteon hub 2
4. Amazon echo
5. Amazon echo dot
9. August lock
10. Haiku fan
Whats the micro module?
waterfoe
The micro module is like a switch, it function like a normal wall switch just that it can be hidden inside the wall or the actual lighting
Pairing it with the 8 keys switch, i can program the various switches to control the numerous lighting in my house.
For example, i have a 8 keys switch in the living room that allow me to create 8 different scenes..... So to ensure all lighting are off before i go out, i can basically create a "Turn off all light" scene to off all power.
Tuakong
Just automated n integrated my AC with SmartThings and Alexa using Sensibo and Tado
Added Hue Go and Bloom lights as well to enhance lighting
Already integrated Harmony hub to Alexa so can power off/on TV with voice
Curtains next
ahyeo
Anyone has used Kudled smart lightbulbs before? It's a China version of Philips Hue and i heard it's compatible. I have a few but didn't set it up.
waterfoe
just curious, since u already have logitech harmony hub, why not just program it to control your aircon?
You should be able to control your aircon via alexa too...
NeonX
What u gonna use got curtains?
Curtains next
NeonX
I was wondering if harmony can control my fan lol.
Anyone any ideas?
bullfrog
Hi,
2. 12 micro module
3. Insteon hub 2
4. Amazon echo
5. Amazon echo dot
9. August lock
10. Haiku fan
Very nice! Don't u just love alexa :)
Sent from under a rock using GAGT
waterfoe
That is what i am thinking too....
Can't wait to get hold of my Harmony Elite to run some customisation....
Yureak
Curtains next
Grats bro!all up must jio me over
Yureak
So your scenes are controlled at the module level and not at the controller level?
waterfoe
The scene can be done on the switch level as well at the controller level....
For example, i have 3 lighting switches in the living room, i can use 3 keys to control the individual lighting point because i might not need to switch on all 3 lighting point at the same time.
If i do need all lighting point to be switch on, i can either physically on the 3 switches or i can program 1 switch than will switch on all 3 lighting at the same time
To me, the physical control are for more generic scene, the more dynamic scene will be done via the apps.
example, scene for movie etc.....
Furthermore Insteon, Amazon Echo and Logitech Harmony are natively compatible so i believe there will be more automation that i can play with....
Meanwhile, still waiting for my friend to pass me the Harmony Elite.....
