I bought another one beginning of this year from Aliexpress and I am still able to control it via openhab.
Thinking of getting a homey and Xiaomi switches (cos they are cheap), will there be any problems? Is this recommended? Do I need to buy a Xiaomi hub to control those ?
Hi anyone know whether is there square smart downlight? Tried googling but seem like all I got are circle
Can use with openHAB through miioclient-mqttBuilt-in LED as light component.
With brightness and colors.
Built-in speaker and sounds library as media_player component.
With play, stop, mute, set_volume and play_media with ringtone ID as media ID.
Built-in luminescence sensor (yes, there's one) as sensor component.
Sensor shows readings in lumens.
Built-in alarm functionality as alarm_control_panel component.
Arm, disarm; night/home/away modes supported with alarm volumes: 5/15/70.
Child sensors as binary_sensor.
Currently supported are: motion sensors, door/window sensors and button.
Can you share which is the model you bought that can be controlled by OH? I assume zigbee2mqtt?
Do you have the link to what you bought?
I’m considering if I should get another hub that works with HA...
I do not have enough post count to submit a link. PM both of you separately.
Is there any particular reason why you want to go for Homey? It is so expensive.Thinking of getting a homey and Xiaomi switches (cos they are cheap), will there be any problems? Is this recommended? Do I need to buy a Xiaomi hub to control those ?
Recently I bought xiaomi Yee light e27 Color bulb from the xiaomi store in Funan.
When I’m trying to add the device to the mijia app. All is smooth. Bulb detected etc.
But when everything is setup. The bulb does not appear in the app
Anyone encounter a similar situation ?
Got it, thank you!!
I believe that’s the newer mi control hub for the China market.
If yours works, then it should be the v2 hub described in HA.
I wonder which one is the v3 that also requires opening up and solder.
The local one’s identifier/model info is lumi.gateway.mieu01
Do you keep your switch on? The smart light requires the switch to be on all the time.
If that's not the case, maybe you can try resetting and reconnecting the bulb.
Got it, thank you!!
yes the switch are on.
this is actually a replacement for my current white/warm e27 xiaomi bulb (Philips).
tried resetting the bulb like countless times but did not really help to get the App to detect the bulb after syncing via wifi etc
Do you guys think it's possible to mod the aqara curtain motor to become a motorized projector screen?
Add a gear at the end etc then connect to the projector screen to turn.
Maybe it is related to your MiHome region setting? Try changing it?
None of them is neutral as SG switch don't have neutral at the switch. I presume you want to replace the switch with a smart switch, please read this as you'll need to bypass/give up the 2 way switching as most smart switches don't support this kind of switch- terminate with wago connector. and do wireless switch at the second location instead.May i know from the pic which is neutral or is neutral even inside? BTW this is a 3 gang 2 way switch
Thanks,
