Aliexpress has lots of options for Raspberry PI. Choose the cheapest.
I bought my Sandisk 16 GB SD from Aliexpress too. I have used it in my Raspberry PI running Openhab for 24x7 for abt 2 years and has no problem. Get those Sandisk w A1 model. It is supposed to be built for frequent read/write.
I'm planning to use this with the aeotec stick.
https://www.home-assistant.io/hassio/installation/
Any pros and cons compare to other free home automation sw?
I got some experience with python
Dooley
Homey can direct integrate with Google assistant already? Anyone tried that? No more "hey Google, tell homey to turn on the tv". Can go straight to "Hey Google, turn on the TV"
yes homey directly intergrates with Google assistant, no need say "tell homey" or use routine to say that on your behalf.
It a touch faster now , most of delay now on voice recognition side. Hopefully that gets faster once Google pushes their smaller voice recognition model that can run locally in "summer"
Sent from Huawei using GAGT
gheesung
I have no experience in HA and I programmed in Python too but I chose Openhab because of the maturity of the platform 2 yrs ago. At that time, Openhab has already a stable mobile app and I liked the Habpanel UI for tablets. Till today, I have not touched Openhab core and all my integrations to Openhab are written in Python and shell scripts. The Openhab rules are written in a kind of Javascript which I preferred compared to HA which is yaml based.
To illustrate some interesting integrations, I have setup Openhab to integrate to flood sensor to detect rain at my balcony. When raining, Openhab will send a notification to my mobile phone which will also buzzed my Miband.
Habpanel is another Openhab UI that is configurable and programmable. Its already come with a rich set of widgets and many 3rd party widgets. If you can program in Javascript and AngularJS, you can create custom widgets. My Openhab also monitors the soil, humidity and lighting conditions of my plants at my balcony and I have created a custom widget to display the data.
gheesung
When reading through the forum, there is a confusion between home automation systems and protocols supported. For a smart home, the more common communication standards are:
1. WIFI
2. Infrared
3. RF (433Mhz)
4. Zigbee
5. Zwave
6. Bluetooth
there are many others like nrf, lora etc which belongs to the maker's space. Generally, at this layer, the transceivers need specific hardware to talk to each other.
Within the generic WIFI standard, there are sub protocols based on TCP/UDP , we have MQTT, miLo (used by Xiaomi), REST and many more.
Home automation systems/hubs are basically a bridge for different protocols and a piece of hardware/software (can be local or cloud based) to manage all the connected devices. We have a spectrum of properietry to opensource systems(the list is not complete):
1. Xiaomi
2. Samsung Smart things
3. Fibora
4. Google Home nest
5. Amazon Alexa
6. Apple Homekits
7. Tuya
8. Hubitat
9. Home Assistant
10. Openhab
Just to illustrate this confusing matrix, just Xiaomi ecosystem alone, it has devices that communicate in wifi, infrared, Zigbee and Bluetooth. Mihome app can also connect to Tuya devices (Saw that recently but have not tried) and Google home can connect to some Xiaomi devices.
For newcomers who have no programming experience, it is better to choose a commercial system. This may restrict to the devices that are supported by that system but also reduces the headache of incompatibility.
Opensource hub such as Home Assistant and Openhab developed connectors that can connect to almost all devices and hubs. You can do very interesting integration but this requires in-depth technical skills (at times required to flash alternative firmware to devices).
Take the analogy of a laptop/desktop, most people will use it to surf the web, documents processing etc. Gamers will make sure every piece of hardwares including the keyboards/mice are the best. The same can be said for a smart home system.
Nainai
Hi all, any recommendations for 4 gang (max) wifi switch that is workable with GH and Alexa for future automation.
Thinking of getting a 1 gang to try first.
Had brought a yeelight smart bulb to try but looks like smart switch is more practical since Wife say every night “ must switch off” switch lol
viix
Nainai
Hi have anyone tried Xiaomi IR blaster with Xiaomi temperature sensor to adjust AC temperature as per what was instructed?
This way the room temperature can be kept at a constant 25 degree.
Is this possible?
gheesung
Is this possible?
I believed that all A/Cs already have in-built thermostat, why another temperature sensor?
Unless you want to turn-on the A/C when the room temperature reached a certain temperature. For this, the mihome app allows you to create "Automation" to execute actions on device when a condition is met.
Superbigfatdaddy
Is this possible?
The room temperature range will fluctuate about 25C, it will not be constant.
Nainai
I think you are right... the best would be cut off power when temperature reach 25 and restart when it’s 27 (example). Wonder does it waste more electricity this way....
Just trying to play around with all the possibility to see how much automation can be achieved.
pustefix
It is best to let the aircon manage the temperature. Please note that the temperature you set may not be the temperature you will get. I've temperature sensors in all rooms and when the aircon is on with the same temperature set, the difference can be more than 1 degree Celsius. It depend on the size of room, number of people, etc.
For automation, I've set one where if it is below a certain temperature, the aircon will not turn on. I've hide the IR remotes and use wireless button to turn it on/off. I've also automated by turning it off in the morning at different time depending on weekday/weekends/holidays.
Nainai
U using smart plug and not IR blaster?
viix
Did something similar with the RM Mini3 connected via homey with the aqara sensor.
The problem isn't that the aircon is setting the temperature lower than 25c. When I look at my aqara sensor graph, the temperature is kept around 25c as what the AC was set to.
But we will perceive it as cold once our core temperature drops after a prolonged duration at 25c room temperature plus humidity lowering the perceived temperature.
What I did instead is to set a schedule to change temperature at intervals and I find this works better. And only if you are sleeping. For daytime activities, i still havent got it correct as there is sunlight factor and activities that you might be doing that changes how you perceive the temperature.
My logic for ac is quite basic. After the target temp is reached, I have a count down set to 60mins which will change the AC to fan mode. When ambient temp increases past 26.5, or humidity increases past 70 (due to respiration and perceived temp will increase) it will revert back to cool mode. And 1 hours before I wake it will auto set to 26c.. when I leave, it will switch to fan mode and turn off after 30mins to keep my AC dry.
So far it works well..
Superbigfatdaddy
For Residential ac, I must say you are putting alot of work into it.
Nainai
Detail and lots of work put in.
Can i ask what is the objective? Better environment? Cost saving?
HMAN
Ha-ha , I have purchased Sonoff products: DIY Wi-Fi switch, single gang switch. Using them for the past 1.5 years to control my routers.
After a while,I hardly do the Google home voice control, the 2 single gang switch are programmed to run fix schedule ,1:40am off MESH network, 2 Google Wi-Fi routers are off and routers are up and running again at 6:40am , repeated daily. Doing so keep the routers at steady state without memory leaking issue (most consumer grade Routers just don't have the stability to run non stop).
1:40am is my sleeping time threshold , force to sleep without Wi-Fi.
Recently I started to add many more Wi-Fi switches from lazada.
1)-4 ways +4 USB Wi-Fi power strip with individual gang control and USB control (on/off on all USB ports).
$27
CE compliance, using SMART LIFE app,
2) single gang with 2 USB ports(2.1A each) ,$14x2
3) UK PLUG ,compact single gang Wi-Fi with power monitoring
~$12
4) Wi-Fi power strip with 3 universal sockets and 3 USB ports
5) 3 Sonoff RF+WI-FI switch
App control:Ewelink
To add t control for my LED downlight , yet with control of mechanical override.
Due to no neutral wire over at power switch area , the choice I have is limited and I am EE trained, sceptical to design flaw with no mechanical isolation. Whenever I am off for holiday, I will shutdown all electrical/electronics appliances and gadgets.
6) broadlink IR Blaster,RM mini 3
Control media box, TV and fans and air-conditioning
Google home simple routines are used to OFF all of them and start all of them.
I tried to group products based on the bundle Wi-Fi remote access app.
Sent from Google PIXEL C using GAGT
