viix
- Nov 17, 2001
Can anyone please share your solution on smartswitch lighting?
And i would like to ask as well, when using smartswitch or smart bulb, assuming you have old folks at home that cant operate it using smart way. They will need to operate the light manually? how can they switch on the light? (i am imagining, the switches are always on but light is off, how can it be manually written to switch on light?)
The smart switch is normally a toggle type, or capacitive touch with LED indicating on and off. Old folk should have no issue using them..
ANother question please.
Does any one use smart downlight? cant really afford Philips brand as the cost is a bomb. While Xiaomi Downlight is not supported in Singapore server.
So, would like to ask your downlight smart solution? Or anyone connect to XIaomi China server and hows the experience?
Using Zemismart downlights linked to hue.. ok for the price. Never use yeelight as these are newer and looks too big for the recessed that I have..
I personally do not like connecting anything to china servers.. quite a pita when they block here and block there...
Hi Home Automation Gurus,
would like to ask:
if i am to install broadlink smart switch (or if you may suggest), then i install LED downlights. I am wondering if the LED downlights come with external driver will work with Smart switch?
And if the downlight is 3 tones type, can i use the phone app to toggle on/off to switch tone?
Any one has recommendation for cheap + good + has safety mark 1000 lumens (10 - 12W) downlights?
your kind respond is appreciated..
Safety mark, only philips and a few local branded lights. most if not all of the others are not safety mark registered anyway.
